Two SLWPRT files - how to combine into one while keeping both feature trees?
I have got one part drawing, in which I created a part1 (one body)
I have got one exisiting, finished part (one body)
Now I like to create a multi body part containing the two body parts above with the complete feature tree.
I then want to edit (roll back and change) the existing part and after changing combine the two bodies in one solid.
How do I 'merge' the two part drawings into one multi-body part?
Thanks, Gerard
SolidworksParts And Features
Answers 4
SF
SF 2012-05-30 Best Answer
Hi Gerard,
1) Folderize all your features in your 1st part.
2) Go to Insert>Part and open your second part into your 1st part.
3) now RMB on the part 2 stock feature and click on "List external Refs"
4) checkmark the "insert the features of orignal part(s) if references are broken"
5) click the "Break All" button
Regards
Mark
GB
GB 2012-05-30
Hi Mark, thanks for your response, but am do not know what you mean by
1) folderize all features - cannot find folderize in help file.
3) RMB? stock feature?
I am 'new' user to SolidWorks. Thanks, Gerard
DS
DS 2012-05-30
Mark,
That’s a neat trick, I did not know you could do that.
Gerard,
By folderize, I think Mark means that you select the features you want to contain in a folder and RMB and select “Add to New Folder”.  If you do this before you insert the second part, you can keep the features separate.
comment imagecomment image
SF
SF 2012-05-31
Hi Gerard,
The folderizing is optional but as David explained, I was suggesting that you could keep your 1st part features separate from your 2nd part inserted features by folders.  So to folderize your feature you shift select or control select the feature you want put in a folder in the Feature manager and then Right mouse button and click on "add to folder."
Once you insert the 2nd part using insert>part.  You will see a feature named after your second part (which is generally referred to as the stock feature because it is not a feature that you can edit in the general sense) if you Right mouse button on it you will get a menu and choose "list external references. It is i that dialog box you can "insert the features of original part if references are broken" and then click "Break All"
Mark
