troubles getting a correct bounding box measure
Hi all,
I have a function which gets the dimension of the bounding box for a sheet metal part. It works fine, or I thought that .... but I have found something quite disturbing.
I came across this part which has a bounding box of 673x198 mm. but when I get the dimensions through the function, it gives me 663x196 mm. And I don't know why, I can't figure out where those dimensions are coming from. I have tried two different ways of getting the dimensions and it is the same.
I discovered that the function gives me the correct bounding box if I flatten manually the part before running the code. But it doesn't work if I flatten the part on the code.
Any idea of what is happening here? I am getting crazy!
Please, could someone give a hint? Thank you for sharing your knowledge.
Cheers,
Rafa
This is the code of the part where I get the dimensions
When I find the bounding-box on the features tree ....
One way of getting the bounding-box:
If InStr(1, swChildFeature.Name, "Bounding-Box") > 0 Then
Set swSketch = swChildFeature.GetSpecificFeature
vSketchSeg = swSketch.GetSketchSegments
For i = 0 To UBound(vSketchSeg)
Set swSketchSeg = vSketchSeg(i)
Length = Length + swSketchSeg.GetLength
xy = swSketchSeg.GetLength
Next i
Length = Length * 1000
xy = xy * 1000
If (Length / 2) - xy >= xy Then
X = (Length / 2) - xy
Y = xy
Else
Y = (Length / 2) - xy
X = xy
End If
If X - Round(X, 0) > 0.01 Then
X = Int(Math.Round(X, 2)) + 1
Else
End If
If Y - Round(Y, 0) > 0.01 Then
Y = Int(Math.Round(Y, 2)) + 1
Else
End If
GetSheetMetalBoundingBox_TraverseNode2 = CStr(X) & ":" & CStr(Y) & " - " & CStr(X2) & ":" & CStr(Y2)
Exit Function
End If
Another way of getting the bounding-box:
boolstatusflat = swModel.SetBendState(swSMBendStateFlattened)
boolstatus = swModel.ForceRebuild3(False)
boolstatus = swChildFeature.GetBox(BoxFeatureArray)
Measure1 = (Abs(BoxFeatureArray(0)) + Abs(BoxFeatureArray(3))) * 1000
Measure2 = (Abs(BoxFeatureArray(1)) + Abs(BoxFeatureArray(4))) * 1000
Measure3 = (Abs(BoxFeatureArray(2)) + Abs(BoxFeatureArray(5))) * 1000
boolstatus = swModel.SetBendState(swSMBendStateFolded)
swModel.EditRebuild3
If Measure1 = 0 Then
If Measure2 >= Measure3 Then
X2 = Measure2
Y2 = Measure3
Else
X2 = Measure3
Y2 = Measure2
End If
ElseIf Measure2 = 0 Then
If Measure1 >= Measure3 Then
X2 = Measure1
Y2 = Measure3
Else
X2 = Measure3
Y2 = Measure1
End If
ElseIf Measure3 = 0 Then
If Measure1 >= Measure2 Then
X2 = Measure1
Y2 = Measure2
Else
X2 = Measure2
Y2 = Measure1
End If
End If
If X2 - Round(X2, 0) > 0.01 Then
X2 = Int(Math.Round(X2, 2)) + 1
Else
End If
If Y2 - Round(Y2, 0) > 0.01 Then
Y2 = Int(Math.Round(Y2, 2)) + 1
Else
End If
Exit Function
End If
SolidworksApi/macros
