Traverse assembly problem (Referenced config not same as config name)
I have a problem when traversing an assembly, the configuration name differs between using the Comp.ReferencedConfiguration and Config.Name methods
I have simplified the code but it shows the problme I am having. Sample assembly attached too which has configurations etc setup.
Macro prints swChildComp.ReferencedConfiguration + " vs. " + swChildConfig.Name into debugger window. I would expect these to be the same but they are not as per the debugger results shown below code. Some are the same some are not.
Sub main()
    Dim swModel As ModelDoc2
    Dim swAssy As AssemblyDoc
    Set swModel = swApp.ActiveDoc
    If swModel.GetType = SwConst.swDocASSEMBLY Then
        Set swAssy = swModel ' Top level assembly
        TransverseComponent swApp, swAssy, 1
    End If
End Sub
Sub TransverseComponent(swApp As SldWorks.SldWorks, swAssy As AssemblyDoc, nLevel As Long)
    Dim vChildComp As Variant
    Dim i As Long
    Dim Indent As String
    Dim swChildComp As Component2
    Dim swChildModel As ModelDoc2
    Dim swChildConfig As Configuration
    Dim swChildAssy As AssemblyDoc
    For i = 1 To nLevel
        Indent = Indent + "  "
    Next i
    vChildComp = swAssy.GetComponents(True)
    For i = 0 To UBound(vChildComp)
        Set swChildComp = vChildComp(i)
        Set swChildModel = swChildComp.GetModelDoc2
        Set swChildConfig = swChildModel.GetActiveConfiguration
        ' Compare assembly reference name to model config name
        Debug.Print Indent + swChildComp.ReferencedConfiguration + " vs. " + swChildConfig.Name
        If swChildModel.GetType = swDocASSEMBLY Then
            Set swChildAssy = swChildModel
            TransverseComponent swApp, swChildAssy, nLevel + 1
        End If
    Next i
End Sub
DEBUGGER:
  HCC0102-L1090-MS vs. HCC0102-L1090-MS
    HCC0102-1-L1070-MS vs. HCC0102-1-L1070-MS
    HCC0102-2-MS vs. HCC0102-2-MG
  HCC0118-L1700 vs. HCC0118-L1260
  HCC0119-L1700 vs. HCC0119-L1080
  HCC0301-L1700-MS vs. HCC0301-L1700-MS
    HCC0301-1-L1700-MS vs. HCC0301-1-L1700-MS
    HCC0101-4-L1700-MS vs. HCC0101-4-L2210-MS
  HCC0302-SS vs. HCC0302-MG
SolidworksApi macros
