Threads from a hole wizard feature inside of an assembly.
Basically I have a part file that I inserted into an assembly file, then I added holes using the hole wizard inside the assembly file.
I'm having trouble getting the threads to show up (in the drawing) from a hole wizard feature that was created in my assembly file, not my part file.
I've tried checking the boxes in options "High Quality Threads" , "Cosmetic Threads" , "Shaded Cosmetic Threads." etc. I made sure all
my views were set to "High Quality Cosmetic Threads." Nothing works. I've checked these boxes inside the part file and the assembly file. I've done
the "Model Items" with the "Cosmetic Thread" box clicked. I've made sure that "View all Annotations" was selected in my "View" options (Glasses).
I've checked the forums, but It seems like the problems that other's have had are with holes that were inserted in to part file, not the assembly. The holes
that are in the part file already, show up fine in my drawing. Please help.
Answers 2
GS
GS 2013-09-25 Best Answer
When you created the Hole Wizard feature in your assembly, did you have "Propagate feature to Part" selected at the bottom of the PropertyManager?
This screenshot is from a Cut-Extrude, but the same option is there for the Hole Wizard.
comment imagecomment image
EP
EP 2013-09-25
At first it still wasn't working, but I think somehow they were still there even though I couldn't see them. Before when I would re-create the view, they would not populate. But after I checked the "Propagate feature to parts", then recreated the view. They finally worked. Thank you very much, Glenn. Now I need some Excedrin.
