First off, thank-you in advance (and if you fix my issue, I may be inclined to write you a check ) So here's the issue, when working in Solidworks 2012 SP 4.0, and in rotating the model with the middle mouse key, i get these unpredictable hangups for several seconds. I tried to ignore at first, but it's beginning to drive me mad. I talked with my IT buddy and he suggested a new video card (considering my card was 512mb and i was running two monitors, he suspected a shortage of video memory), so he ordered me a fire pro 5900, installed it this afternoon (with the SW certified driver), and same issue (not to mention I thought editing a part in an assembly would be an improvement with this new card, no luck, but I digress). Like I mentioned, the hangup lasts for several seconds and then jumps back to life. In observing the task manager, during rotation processor sits right around 10-12% and drops to 5% on the hangup... It's very strange, indeed. Hardware or software??? I'm tempted to believe it's a software issue (possibly a driver) considering the stations hardware is current.
With some google searching I found a similar issue with SW 09 and windows aero settings, this isn't the case with me. Could it be any other software settings? Any feedback would be greatly appreciated.
Here are some of my workstations specs (if you'd like to know anything in particular, please let me know):
SolidWorks 2012 4.0
Windows 7 64bit
Chip: AMD FX-8150
Mobo: Gigabyte (exact model unknown)
RAM: 4 x 4gb
Card: FirePro V5900
Monitors: 2 x 22"
Mouse: Logitech G500 (with logitech software which opens on startup, holds some of my programmed keys... maybe i should try disabling this)
3D Mouse: none
Thanks again!
Cheers,
John
SolidworksUser Interface
What videocard driver are you using?
I installed the cetified driver from SolidWorks website:
http://www.solidworks.com/sw/support/videocardtesting.html
Keep in mind that I was having the issue, thought it was gpu memory, so i upgraded the card. So the problem was apparent with the old card and the new Firepro 5900... Does that rule out a GPU driver issue?
I would un-install the Logitech mouse drivers to see if that is the issue.
After that I would go to one monitor to see if that resolves the issue.
Cheers,
Anna
Uninstalled mouse driver, no change. Shut off second monitor, no change.
Any other ideas?
Thank-you
Bummer..... I am out of ideas at the moment.
Cheers,
Anna
Is it possible that this could be due to the AMD FX 8150's eight cores and how solidworks is caching those cores? Please someone smarter than me help... !
Thank-you,
John
The best advice I can provide in this situations is to send an Rx report to your VAR.
Hurray!!!
Someone else is getting this problem!!!!!!
On a brand new (well couple of months old HP z420) possible the first one that was in use in UK
I'm running a c602 chipset with a e5-1620 processor but...................................... I am also running the v5900 graphics card
Generally speaking the workstation is very fast but this hang up is driving me nuts - also happens sometimes in referencing geometry in sketchs.
General symtoms-
Doesn't happen in shade mode (infact rotation in shaded mode is insane fast and smooth)
Happens in wire frame mode
Seems to happen in sketches 'sometimes' when referencing geometry
These problems did not happen on my old workstation with a v5700 graphics card on x38 chipset & e8400 processor.
Ran the new computer on passmark and it gets better rating than the average for both the graphics card and processor (the graphics card gave about 11% increase on the mark in the passmark data base for the model!!!!). So can't see there is anything fundentially wrong with the workstation other than drivers or something aren't getting on with SW????
No idea why this is happening other than drivers.
Hurray! haha. I thought I was the only person on the planet having an issue like this.
Sounds like your issue began when you started running the v5900? I was having mine prior to the card upgrade...
Whatever it is, it's very annoying and it's affecting my productivity, I just wish i knew what to replace.
Thanks for the comment..
Cheers,
Johnny
Well yes and no. It's a new computer with that graphics card in - so it could still be a whole host of possible problems I guess - even hp's version of windows 7 professional??
But yes putting all other things aside it would appear we have the same graphics card. I think I did noticed that there is a newer version of drivers for this graphics card but it's not been certified by SW. I went with the older version certified by solidworks. Maybe the new version uncertified works?
On the otherhand could it be something that both our motherboards do that solidworks doesn't like??;
I noticed a hang last night. I was trying to simply edit a dimension in a drawing and it just stuck there for like 20 seconds not allowing me to do anything. If you didn't know better you would have thought SW was about to crash........ but no it just came to life again and carried on like nothing happened. This has happened a few times in the last few weeks the change dimension hang.
The rotation in wireframe for me isn't so much a hang but sticking if you like. Doesn't seem to be much to do with size of assembly or part. The wire frame rotates and then just starts jaming and then the next second starts moving again. You would say the graphics card is running out of RAM but at 2GB of RAM this just can't be true.
When I get a chance I will have to try and get my retailer support onto the problem.
The mobo could be the issue, but how that crosses to both of our applications is unclear. I'm running the newly released AMD FX 8150 with a board newly released to utilize the chips 8 cores (I think I was my IT guys guinea pig). I understand Windows is having trouble scheduling these processors, (in both hyperthreading and light threading applications) SolidWorks may be sharing this caching issue. Apparently I have an Intel I7 on the way, so the computer will get a new board and chip and I suspect the problem will go away. If it doesn't, it's time for a career change..
Cheers,
Johnny
what is strange about all this is that, am I the only one running the AMD FX 8150 while running SolidWorks? ah well ...
Well my e5-1620 is similar to the i7 family but e5-XXXX are a newer line of processors than i7. My 4 core e5-1620 actually gets better results on the pass mark data base than your 8 core and that will be using the full multithread capability. My c602 motherboard is a newer chipset than is used on i7.
I'm personally leaning towards drivers
Checking my old HP workstation that was actually running the FireGL v5600 and only slowed down on big assemblies. The new Firepro v5900 should be about 4-5x faster than a v5600 and has 4x the memory so in theory it should be very hard to slow down or make hang or stick.
Oh my workstaion is also using DDR3 ram.
Drivers it's got to be???
Have you experimented with installing the newest driver from ATI (or nVidia for whoever has nVidia cards)?
I was wondering whether to do that but the present driver is certified and RX says it's up to date. But I think there is a newer driver which isn't certified (does it take time for SW to get around to certify driver?).
Just do a quick test. You can always revert to the certified driver.
For example, at home I am running an AMD FirePro v4900 on an ACER computer. Guess what? I cannot even start Windows with the certified driver! So I used the latest AMD driver and both Windows and SW are extremely happy.
OK will do that later today when I get a chance and let you know how I get on.
Installed the latest V5900 driver and no change for me.. If it's drivers, you think i need to flash my mobo?
I know you said you dont think it is an issue with Aero, but I would definately recommend you go into the personalize settings on your desktop and use the standard Aero theme for windows 7. Also go into computer properties and selecct advanced system settings, under performance settings use either "let windows choose"or"best appearance".
Another thought is this could be related to GDI objects.
I had the same issue of hanging center button rotation. My problems started after updating this computer to Windows 7. I was using a Logitech wireless mouse and keyboard. When I went to an old cabled mouse the problem went away so I bought and installed a microsoft wireless mouse and keyboard. I installed their driver and removed the Logitech drivers. Still had the same center bitton issues. I then removed my 3DConnexion mouse and driver and the problem went away. I'm now back to using the wireless Logitech mouse and I'm not experiencing anymore hang up issues.
The Aero changes doesn't seem to make any difference. Thanks for your comment.
What are you referring to with this GDI objects? Thanks again!
So was it the driver? or the mouse? Were you getting the hang when rotating with the keyboard?
Sooo... My workstation got a makeover...
Changed the chipset to an Intel Core I7-3770K clocked to 4.2 Ghz
New Mobo to compliment the chip
New Ram
New SSD (so all software had to be reloaded)
THE PROBLEM IS STILL THERE! I dont understand how this glitch survived that. >sigh<
I thought for sure that it'd be resolved with the new hardware.
I just can't believe that I'm the only person (along with Richard) that is experiencing this... What in the hell can it be? It's almost become an obsession of mine to solve it.
If it were in fact drivers, then others would be complaining, right? I mean, i'm not the only person running an I7 with a FirePro 5900 am I?
Aye ya yai, if ya can't tell i'm a bit frustrated.
What else could cause this? a failing power supply? I tried the mouse & Keyboard thing with no prevail. Is there anything in SW settings that could contribute to this? Catalyst settings? Maybe I should post this on an Intel forum....
Thanks..
Cheers,
John
Unfortunately, I don't have a solution (yet), but it's nice to know that I'm not the only one having this issue. I, too, was going to try to 'just live with it', but it's been driving me crazy (it hangs a LOT).
It started when I switched to a new computer (with a new video card). I figured it had something to do with the hardware. I updated all of the drivers and basically tried everything I could think of, but the problem persisted.
This morning I found the "switch to Aero Theme" solution, so I changed the computer theme to Aero. So far (1 hour), I haven't seen the issue. I'd me amazed (and very happy) if this actually solves the problem.
EDIT: I've been using SolidWorks all morning in the 'Aero Theme' and have yet to see the problem. So far (fingers crossed) it seems to have solved my problem.
I was experiencing the problem with a FirePro V4900, SW2012, Win7 64bit. Changing to an Aero theme fixed it. Thanks!
I also had this problem a while ago and it was fixed by changing the Aero theme. Its being about a month now with no more problems. Thanks to whoever mentioned to me that this was a problem.
I've tried the Aero thing with no prevail. Can you tell me exactly what you did so i can replicate it? Thank-you much.
This thread gives specific instructions on what to do (I hope it helps):
I made the changes and it seems to have fixed the issue (thank goodness). It has been several days and the problem has not reoccurred.
Alin
After installing the latest drivers for the V5900 (think they were june 2012) it would appear my problems have gone!!!!!
Been running say 2 weeks with them now and all seems fine
I am very happy for you Richard. It might be a good idea to notify your VAR too.
SolidWorks should be made aware that some of the certified drivers for ATI videocards are not working, while non-certified ones do. Most of the worst possible bugs are the direct result of buggy videocard drivers.
