Technical Issue: "Insert as a cabinet" function fails to render graphics in 2D Cabinet Layout
I am experiencing a critical issue in SOLIDWORKS Electrical where I am unable to insert 2D footprints or simple representations into a 2D Cabinet Layout sheet. Despite having the manufacturer parts properly configured, no geometry appears on the drawing.
When attempting to use the "Insert as cabinet" command for a component in the Cabinet Layout tree, the command executes, but no graphical object (neither the DWG footprint nor a simple rectangle) is rendered on the sheet.
https://youtu.be/Qe7qM7lMuu8
Answers 3
CM
CM 2026-01-21
How was the symbol created? Imported dwg? If imported verify the Scale of the symbol, Verify that the Entities are in Model space, and you have an Insertion point defined.
AS
AS 2026-01-22
The problem is that even without a drawing, I cannot insert a square or rectangle with the specified dimensions. The drawing seems to be normal. I tried to simply copy and paste it, and it worked. Below, I will provide another video with the project settings, if you are interested.
https://youtu.be/KP9Y9vvo2c8
CM
CM 2026-01-26
Next I would try resetting your Interface configurations, to do this with no project open, go to the tools tab of the command manager-> interface configuration -> on the main tab click reset all interfaces.
