I know this may seem like a small item, but it bugs me to no end. Should a system option stay the way it is set regardless of the the document being opened or created?
My issue...multiple times a day I have to go into my options-display/selection and turn on my dyanamic highlight. Am I going crazy?
SolidworksAdministration
Probably not. The same thing happens to me, but it's once or twice a month instead of mulitple times per day. Also Options > System Options > Sketch > Over defining dimensions the "Set driven by default" box unchecks itself occasionally. For me it started with SW2012. I remember something in another discussion about it affecting some people who use a 3d Connexion device.
I do have a 3d connextion device...hmmm
do you have the latest driver for the 3D device? - they do help. also re-calibrating it can help - the driver actually turns that setting off on pupose when ever you are rotating, and is then supposed to turn it back on when you stop (this is to help performance). so if it thinks you are still rotating the model, it will leave it off.
Im glad you mentioned that. I have a 3d connextion device................
Also thought i was going crazy with some of my system options changing!!! Put my mind at rest a little knowing its not me now.
Jonno
it was the latest driver a few months ago...I will go and find out right now though.
Thanks
So far, the updated driver seems to have fixed my issue.
Thanks
Good luck,
I updated my driver when I downloaded SW2013 sp 0 but it's still happening occasionally.
occasionly vs. multiple times a day is a win in my book!! lol
