SW2014 Hole wizard not working anymore (not a memory problem)
Hello
I have been using Solidworks 2014 without any hiccups for the past 2 years on a HP elitebook 8570w laptop (64 bit, 8 Go RAM, dedicated graphics card). I used extensively the hole wizard in many designs.
Now, when I click on the Hole wizard, the following error shows up :
''Out of memory or other error trying to initialize data source from standards file "C:/Users/   ...my file path...   /HoleWizardFavorites.mdb''
I click OK, then :
"Cannot define a valid configuration of the profile" (translated)
Under Options/File locations, HoleWizard in the dropdown menu, the correct path is directing to HoleWizardFavorite.mdb
Under Options/Hole Wizard Toolbox, the following error message appears (translated) : "Cannot access main database because of an access error of the following database : " There is no name specified for the database that has an access problem. Still under this tab of the Option Panel, the file path is C:/Solidworks Data/ . In the folder C:/Solidworks Data/, I can find ToolboxVersion.dat, ToolboxVersion.xml and a few other folders.
What should I do? Right now I cannot use the Hole Wizard. I am pretty sure it is not a memory issue since I have 8 Go RAM and the OS is 64 bit.
I uninstalled my anti-virus (Kaspersky) and changed C:/Solidworks Data/ from read-only to read/write
Thank you for your help,
Olivier
SolidworksParts And Features
Answers 8
AL
AL 2017-10-20 Best Answer
Have you tried running Windows Repair in order to reinstall the ToolBox? Perhaps that could be of help but I have no idea to be honest.
SF
SF 2017-10-20
I tried the Windows repair but my problem is still happening...
AL
AL 2017-10-23
Perhaps this could be of use:
Regards.
SF
SF 2017-10-23
Unfortunately, I already tried the solutions in this thread. I replaced the C:/Solidworks Data folder on my computer with one from a colleague. I also replaced my version of HoleWizardFavorites.mbd with a working one from my colleague. Following this, I made sure the file paths were appropriate
I guest my last option would be to uninstall Solidworks and do a clean re-install?
AL
AL 2017-10-23
That would be what I would do but I would wait for someone else to respond before doing this, unless it is impairing your ability to work
IH
IH 2019-02-13
We just "upgraded" to 2019 and I haven't seen this message for years, and now I'm getting it again.
KC
KC 2019-02-13
Would running something like this help flush things?
CCleaner Official Site | Clean & speed up your PC | Piriform
​Kevin
RW
RW 2026-09-07
I recently had the same issue. It turned out to be a memory problem. The system had been running for several days. Restarting the system solved the problem in this case.
