Since installing sw2009 i had constant freezing problems
Tried untick 'uppearance-effects-hide underlined letters....'' butdidn't help
I was running dual monitor display and after switching to only onemonitor
this problen appears to stop. i was able to work whole day withoutfreezing.
Not sure if 2X monitors were causing problem (i will give couple ofdays to test)
However 2 monitros is great advantage and I wonder has anybody hadsuch problem solved and was able to use dual display?
Regards, ZiggySolidworksAdministration
Aside from that, I am using two monitors and have no issues that Iam aware of that are related to having them.
No problem here with 2 monitors on FX3700
I also use 2 at home with an FX1700 and no problems.
Sorry not much help, bur confirmation that it does work.
Thanks guys, sorry to hear it is only me with that problem
Paul, followed is my PC spec
Dell precision PWS490
Intell (R) Xenon (R) CPU
5140 @ 2.33 GHz
4GB of RAM
NVIDIA Quadro Fx3450/4000 SDI
Driver ver. 6.14.11.6950
below is response from our IT guy
in my video card option there are TV / Video settings and it can beused for that purpose
I have no idea what the power supply is? Just tell him your systemis a Dell Precision 490 workstation. As for the graphics card it isthe nVidia Quadro range which were designed for 3D cadapplications. It was on their approved list of video cards at somestage?
regards
Ziggy
Dell Precision T5400 Mini-Tower
Quad Core Xeon Proc E5420, 2.50GHz, 2X6MB L2 Cache,1333MHz
8GB, DDR2 ECC SDRAM Memory 667MHz, 4X2GB
nVidia,Quadro FX 4600,768MB dual VGA or DVI
146GB 3Gbps SAS, 15K RPM Hard Drive
Microsoft Windows Vista Business x64 Edition
28" 16:9 Flat screen monitor
19" 16:9 Flat screen monitor
Solidworks 2009 SP2
Anna Wood offered the suggestion to toggle the F5 key when thewindow freezes, this will bring up the Selection filter toolbar andseems to refresh the window. To my knowledge she is running dualFX570 cards and I am using 1 FX1700.
Just got a 2nd FX1700 today so I'll see how that helps thesituation...
I reinstalled my video driver (the latest certified for Quadro1700s) and my Pilot drivers and my machine appears to be runningbetter. But that hasn't worked for everyone. There haven't been anysecurity updates, etc installed for quite some time. I can't figurewhere its coming from.
SW2009 SP2.0
NVIDIA Quadro FX 1600M
System:
HP xw8600 Workstation
Quad Core Xeon Proc E5430, 2.66GHz
8GB RAM
nVidia Quadro FX 4600,768MB
2 x 125GB SAS, 15K RPM Hard Drives as Raid 0
Microsoft Windows XP 32 SP 2.0
2 x 19" Flat screen monitors
Systems:
Dell Precision PWS490
Xeon CPU 5160@3.00GHz
2.99GHz, 3.25GB RAM
XP SP 2
nVIDIA Quadro FX3450/4000 256MB
SW 2009 SP2.0
(Also, note to update the vault and installation mgr to the sameservice pack level as the latest users. Apparently important in2009.)
Also, the other user outside of our group that was having problemsis using a machine that isn't really rated for Solidworks. Intelintegrated video, etc. I updated his service pack and told him notto run Outlook at the same time if possible. Also give him the infoabout having windows explorer not casche the tumbnails. So fartoday he's running fine. But it's early...
Other than that, SP 2 has been running smoother than 2008 or theprevious 2009 service packs.
Keeping our fingers crossed.
i had logdged countless support tickets/emails,
had 3 remote sessions with support, did cleanup my PC, installedwindows SP3,
replaced motherboard and video card, what only left was to rebuildPC.
Just as a 'fun' i did rolledback my driver, it went far back
to 8.1.7.6 (year 2006) since then (4 days) no problems no lock-ups
Those freezings were related mostly when in drawing environment
It looked like SW is absolutely ignoring my problems (thought theyreally were only my). Im my humble opinion SW2009 has poorlywritten software, can be easily corrupted and is unstable. Cancreate problems while running antivirus, doesn't support properlylatest video driver (or vice versa)
Comparing to 2008 (stability) - no match
I had to (many times) create new SW registry in CURREN USER, evensome system options are beeing changed after lock-ups. With allthose as above i am fine but in my opinion it is not a solution, westill do not know what is causing problems and how to solve it. Atthis stage i am lucky an run OK for now.
I think for all those losses SW should be accountable to someextend
SW started working just fine after closing (killing with taskmanager) windows explorer.
(SW 2008SP5.0 64 bit, core i7 workstation with Vista Business 64bit)
Edit: Could not repeat that jum. Might have been something elsealso ...
InstalledFreeCommander just incase. Looks fine.
Any suggestions, I don't like to work with real view enabled. Ihave real design work to do not look at fancy graphics allday!!!!
We had same problems on some DELL M6400. We fix the problem:uninstall this applicationhttp://silverlight.net/
Maybe it helps you
Daniel J
Any help?
I never had any trouble with SW2003.
Kevin Hunt
have to run in open gl mode and lower the performance of the pc
works ok got better with sp2. something or another
sw seems to crash alot when you upgrade give it till about the endof june or sept usually runs good for me then until the end of theyear when its time to upgrade adn go threw th e problem again????
3 yrs and running same issue every year
06 to 07
07 to 08
and 08 to 09
Hey John,
My system has been locking up daily as well. It happens when I zoom in on large drawings with complex-surfaced (knit surfaces, etc.) parts. Once my system locks up I can't even bring up the Task Manager. I end up having to hold my power button down for several seconds to shut down my machine. Then, after I restart my machine, open SolidWorks2009, and open the drawing, the drawing views on the sheet I was working on do not display the parts other than a few notes and arrows.
This may be because my setup (Dell M6400, (2) 2.8 GHz Intel Core Duo Processors, 4GB ram, Windows 64 bit, FX2700) does not have a video driver listed on the "compatible video driver list" on the SolidWorks website.
Can you tell me about your computer, video card, and operating system
I may have to go back to Windows XP 32 bit or forward to SolidWorks2010.
Tom Welsh
Sr. Prod. Dev. Consultant
Philadelphia, PA
215-833-2321 (m)
Tom,
If you have a Quadro FX 2700, why are you not using approved video drivers? There are approved video drivers available, choose "Vendor: Dell" "Model: Precision M6400", then "Graphics Card Model: nVidia Quadro FX 2700M". http://www.solidworks.com/sw/support/videocardtesting.html
This definitely sounds like a video card problem with the drivers/hardware.
Tom,
I'm actually surprised that I saw this response- did you notice the post date?
I am not having this issue anymore with my new machine (hover over my profile for specs). My previous specs when I was having this issue with SW2009 was with a Dell 490, dual core, 4 gb memory and Quatro FX4600 video card.
Hey Charles,
There are no approved video drivers for that combination of Hardware/OS.
Peace,
Tom Welsh
This is the driver you should be using: http://www.solidworks.com/downloads/videocarddriver/dell/R227968.exe
It is version 8.15.11.8621. Is that the version you are using?
Also, I am also having issues with my ATI card at home crashing (it is a Radeon). It is not SolidWorks related, and seems to happen about once a day. Windows manages to reboot the driver (hooray for Win 7) so I do not have to restart my computer, but it is still a little frustrating.
Edit:
I should also add. The original poster was asking a question about an early service pack of SW 2009 that had a known issue. This issue was resolved, and the proper drivers will fix it. Which service pack of SW2009 are you running, SP4 or 5 or 5.1?
Hey Charles,
It was worth a try, but that driver was no help. That driver is for SolidWorks2010 and Windows 7, 64 bit. I am running SolidWorks2009 and Windows 7, 64 bit.
Thanks for weighing in on it anyway.
Peace,
Tom
Oh yeah, I'm on Service Pack 4.1.
Tom, whatever it's worth, here's the thread I've compiled with all I've seen on this issue:
https://forum.solidworks.com/thread/32276?tstart=0
Good luck.
Hey Ziggy and all others with SolidWorks Freeze problems,
I finally solved my freezing problem by doing the following:
__________________________________
Go to
Tools > Options > Assemblies
and un-check the Use Large Assembly Mode........ box.
Done.
Hope this helps some of you.
Peace,
Tom Welsh
