Hi guys,
I am new to SolidWorks and am currently trying to complete a turorial to make an F-16.
I have made all the surfaces of the F-16 body and knitted them into (what apparently seems to be) an airtight model. However, it refuses to let me form a solid body out of the knitted surfaces as there is obviously some error. Sometimes when I try, it gives me a "intersecting geometry" error, or sometimes just nothing at all.
I have uploaded the file with this post and please have a look at "Surface-Knit12" in the features tree. Once you open it, you can clearly see the surface is all enclosed and knitted, but it still refuses to let me from a solid body?
If anyone knows of any tricks or ways to solve this problem, please let me know! I am pretty desperate to get this tute completed and any help would be greatly appreciated.
Thanks.
SolidworksSurfacing
Min,
I believe it is the leading edge of your wing that SW has a difficult time with making solid (see below). Looks like a topilogical (and physical impossiblity) to do that shape there where two surfaces com in tangent to one another as a knife edge.
Regards
Mark
Dear Mark,
Thank you for the suggestion, I will try to offset the surface so instead of having a knife edge, the edges are flat in a sense. It might take me a while as theres a lot to change, but I will let you know how things go.
Thanks again, I really appreciate your input.
Regards,
Min
Hi Mark,
I filletted the wing edges and that didn't help. It turned out I had gaps in some of the surfaces I created, even though I chose the correct entities etc when creating the surfaces. Why does SolidWorks create these unnecessary entities/leave open gaps? Is this a program error/randomly generated?
Basically, it is fixed now by using Tools > Check > Extensive Surface Check > Then manually filling in the gaps.
Thankfully that worked as I almost just gave up after staying up till 8am trying to solve this.
Thanks for your suggestions.
Min
Hello Min, could you share with me that tutorial ??
Thank you very much!
Sorry the video files are content protected and I needed to buy a user name and password in order to view them.
Otherwise, I would be happy to upload the files to share.
