Strange Macro problem hiding a row in a Drawing BOM Table
Greetings,
Have created a Macro to create 10 rows above the selected rows (Thanks mostly to this forum therefore thanks to many of you!) and I would like for those same row to be hidden.
In fact I shed the insert portion and am simply trying to hide a row in a BOM table. Code is below. The result (Solidworks 2013) is the system creates a phantom row and hides it. I know it is phantom because when I try to show the row it simply disappears. Quite strange!
The code below has more than required because I just wanted to one "RowHidden" line of code to work. All the other stuff is to complete teh overall macro once this works. You can see that I am trying to simply hide the 3rd row.
Option Explicit
Sub main()
    Dim swModel                 As SldWorks.ModelDoc2
    Dim swSelectionMgr          As SldWorks.SelectionMgr
    Dim swDrawing               As SldWorks.DrawingDoc
    Dim swAnnotation            As SldWorks.Annotation
    Dim swTableAnnotation       As SldWorks.BomTableAnnotation
    Dim firstRow                As Long
    Dim lastRow                 As Long
    Dim firstColumn             As Long
    Dim lastColumn              As Long
    Dim Do_It                   As Boolean
    Dim Hide_It                 As Boolean
    Dim i                       As Integer
    Dim m                       As Integer
    Dim InsertRow               As Integer
    Dim HideRow                 As Long
    Set swModel = swApp.ActiveDoc
    Set swSelectionMgr = swModel.SelectionManager
    Set swDrawing = swModel
    Set swTableAnnotation = swSelectionMgr.GetSelectedObject6(swSelectionMgr.GetSelectedObjectCount2(-1), -1)
    Set swAnnotation = swTableAnnotation.GetAnnotation
    swTableAnnotation.GetCellRange firstRow, lastRow, firstColumn, lastColumn
    'MsgBox "First selected cell's row     = " & firstRow
    'MsgBox "Last selected cell's row      = " & lastRow
    'MsgBox "First selected cell's column  = " & firstColumn
    'MsgBox "Last selected cell's column   = " & lastColumn
    For m = 0 To 0
      HideRow = CLng(firstRow + m)
      MsgBox "Row Hide placement  =" & HideRow
      'MsgBox "First Row  =" & firstRow
      swTableAnnotation.RowHidden(3) = True
    Next m
End Sub
Any help is greatly appreciated!!
Danny Bradford
SolidworksApi macros
Answers 4
PO
PO 2014-05-08 Best Answer
Change:  Dim swTableAnnotation       As SldWorks.BomTableAnnotation
To:          Dim swTableAnnotation       As SldWorks.TableAnnotation
DB
DB 2014-05-08
Well, actually that is how I had it for the majority of my tests. I only added "Bom" on the last test in fact and I forgot it was there. Both options do the same thing.
Thanks for the response!
PO
PO 2014-05-08
You mention that you are wanting to hide the third row, but you are actually trying to hide the fourth row (the row numbers start at Zero).  Does your table have four rows?
DB
DB 2014-05-08
Yes it has plenty of rows. If it would hide any of my realy rows I could work with that. The problem is that it places some virtual row in hide mode that does not really exist.
I have used a variable to define the row number and hard numbers and they all do this same thing.
