I accidentally unchecked the "Start command when creating new drawing" in "PropertyManager/Model View/Options".
So frustrated that now I need it but it just disappeared, I cannot find and check it(Start command when creating new drawing).
Could someone please advise? Thank you anyway.
I don't have SolidWorks now to check, but I believe if you'll activate the "Insert Component" command the option will be there to select.
Hello
1- Select new command
2- Select drawing and then click ok
3- Select size of sheet
4- select model view command
5- in PropertyManager you can check and uncheck Start command when creating new drawing
Yes, I checked "Start command when creating new drawing", even closed the file without saving it, the function will work when next time open a new drawing.
Appreciate you so much!!
