I need some help with drawing a splined shaft.
The spec calls out "J498B with major diameter modified 9 teeth 16/32 pitch 30 degree flat root.
On the drawing it has one dimenson on the diameter which is 15.5MM. The shaft is supposed to be a 5/8" shaft.
I don't think I have enough information.
Tim
Do you have access to a Machinery's handbook?
I would assume that the dimension they give you is the Pitch Diameter, you can get the Diametral pitch by the formula
D = N/P (where N is the number of teeth & D is the pitch diameter).
The Base Dia. is D*cos(Standard Pressure Angle).
The Major Dia. is N+1/P
The Minor Dia. is N-1.35/P.
Should be all you need to draw.
Thanks
I just needed some verification.
Thanks.
Tim
Yes. Sorry. I didn't see your major dia. modified note.
Maybe this will help?
Aaron-
Thanks for posting that. I wish I knew how you drew the tooth cut. Macro?
Thanks again.
Tim
magic.... A true magician never reveals his secrets... lol
Here at my company we have a 3rd party software called "geartrax" from a company camnetics. They do offer a 10 free trial (however i dont know if there are any limitations).
It will also create:
spur gears, sprockets, belt pulleys, ...
I saw the specs you had and input those and it created that part as you see it.
Aaron-
Thanks for taking the time to run it through for me!
Tim
