when ever i export the autocad file to Solidworks in SAT format the uniots are changed for example i imported the block of 100x100 mm from autocad to solid works then it is changed in 100x100 in how can i fix the problem
SolidworksParts And Features
Ali,
Just change the units back in tools>options>document properties>units.
Ali,
I suspect that the problem is in AutoCAD, that your units aren't what they think they are. If you can't change the units there, then you may be able to change them in the SAT file. I know that this can be done for STEP files. If the SAT files work like STEP files, then the unit information is written in the header. The trick with STEP is that you also have to change another entry which tells you how many characters are used to define the units. Try looking at the threads in the "More Like This" box to the right.You might also ask this question in the Import/Export Forum.
Jerry Steiger
