Computer is a HP Workstation Z440
Video Card is HP Quadro M4000(Nvidia)
Video card driver tested: Latest certified on SW website and latest on Nvidia website.
Windows 10 Entreprise 1709
Solidworks was version 2018 0.1 when the upgrade to Win10v1709 was made.
Right after SW start crashing when we try to create a drawing.
Or as soon as I want to draw.
So I did the update to SW 2018 SP3.0
Still have the same issue.
Video driver was the latest from windows update.
So i tryed the latest one from Nvidia. Still crashing.
Tryed the latest from SW website who's certified.
Still crashing.
It give me module fault: system:000b096
when looking at swxJRNL.swj, here are the results:
' C:\\Users\\AMorisse\\AppData\\Roaming\\SolidWorks\\SOLIDWORKS 2018\\swxJRNL.swj - journal recorded on 06/27/18 by AMorisse
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Dim longstatus As Long, longwarnings As Long
Sub main()
'The stack trace for this error is:
'Build: d180515.002.BGS sw2018_SP03
'{KERNELBASE:7FF92D863FB8:00013FB8} KERNELBASE:RaiseException
'{clr:7FF921AE06FA:000606FA} clr:DllCanUnloadNowInternal
'{clr:7FF921AE0BAA:00060BAA} clr:DllCanUnloadNowInternal
'{PresentationFramework:7FF8EE337252:00EC7252} PresentationFramework:Unknown
'{PresentationFramework:7FF8ED923F9B:004B3F9B} PresentationFramework:Unknown
'{clr:7FF921AE1399:00061399} clr:DllCanUnloadNowInternal
'{clr:7FF921ADF600:0005F600} clr:DllCanUnloadNowInternal
'{clr:7FF921ADF513:0005F513} clr:DllCanUnloadNowInternal
'{ntdll:7FF931254CBD:000A4CBD} ntdll:_chkstk
'{ntdll:7FF9311CE465:0001E465} ntdll:RtlUnwindEx
'{clr:7FF921AE01B4:000601B4} clr:DllCanUnloadNowInternal
'{clr:7FF921AE0173:00060173} clr:DllCanUnloadNowInternal
'{ntdll:7FF931254C3D:000A4C3D} ntdll:_chkstk
'{ntdll:7FF9311CD1B8:0001D1B8} ntdll:RtlWalkFrameChain
'{ntdll:7FF9311CB623:0001B623} ntdll:RtlRaiseException
'{System:7FF9191D0986:000B0986} System:Unknown
PLease Help!!!!
SolidworksAdministration
I need to add, since the problem was only when trying to draw, I tryed running edrawing x64 outside of SW.
Software is crashing right away.
Related?
Dany,
Although not a direct answer to your question, whenever I'm having repetitive crashing issues, before I do anything else, I do these procedures.
1./ Run RX>System Maintenance
2./ Local Disk> Properties>General> Disc Clean-Up
3./ Local Disk> Properties>Tools> Optimise
4./ Local Disk> Properties>Tools>Error Checking
5./ Restart
If it continues after that I would then do a Repair on the Install
Have you tried updating the inbuilt Intel Hd Graphics card drivers as well. if that doesn't work try the hotfix below.
hmmm like I wrote... I don't have an Intel HD Graphics card.....
Second line of my initial post, There is an HP Quatro M4000, Nvidia Chipset.
Will try the hotfix
already tryed this also the repair.
Negative.
Hi Dany,
It looks like a pre-requisite problem to me based on the stack trace: a visual C++ redistributable or .NET Framework. That would spill over into other software and also not get resolved by a reinstall/update. I don't have the support skills to advise a solution, but please get in touch with your VAR. They will be able to help.
Jeff
Hi there,
Most of the system comes with preinstalled basic intel graphics card, for verifying go to
Device manager -> Display adapters
Did the hotfix worked?
As said, this workstation DON'T COME with a pre-installed video card.
So, there is NO Intel HD Graphic on it installed.
Will try the Hotfix today. I am IT for this companie only once a week.
So only can work on this trouble the wednesday of each weeks.
So, Hotfix's not working with SolidWorks 2018 SP3.
I receive this error message:
I did a backup of the 2 DLL the hotfix try to replace then i've replaced them manually.
So I don't get the drawing section crashing anymore.
But there is a new error message when I try to open a project who already exist:
If I try to start black, I get this error message:
Then I click OK and nothing happen. I get the SolidWorks background and nothing open.
See my latest answer please.
Hey Dany,
Have you tried contacting your VAR about this? You have 2018 so I'm guessing you also have an active subscription? They'll be the one best placed to assist you on this as they have a direct link to SolidWorks while most users here are just casual users.
what is a VAR? lol sorry for this dumb question. I speak french, so I don't know every english abreviation.
tnx
Salut Dany,
Un VAR est ton revendeur SolidWorks.
Thank you Alex, Well, the VAR wasn't able to help at all. That's why I am on the forum right now.
So for now, i've uninstalled everything and will start back fresh.
Problem is, Workstation don't have acces to internet. so when files are missing, I need to connect away remotly each time... lol
Pourquoi est-ce que ton VAR n'etait pas capable de t'aider? Normalement, il devrait t'assister et si ils ne sont pas capable de t'aider plus escalader le plus vers le monde de SolidWorks. Ce n'est pas a toi de courrir apres SolidWorks.
The VAR should help you and is supposed to. If they aren't able to, they should escalate the problem to SolidWorks so that SolidWorks can try and diagnose the problem. It is not your duty to run around the forums to try and get an answer.
Have you tried a clean install with a registry whip? Files shouldn't go missing after the installation. Try keeping the computer remotely connected until you finish the installation.
They just said they are not a support departement. they only sell. They told me to contact SolidWorks directly for specific help.
As for the clean install, this is what I am doing right now. need to download few missing files since workstation don't have acces to internet.
Do you have an active subscription? If you do, you pay a fee every year to them for them to support you, if that is the case I cannot believe they gave you that answer. I'd be flipping tables to get answers
Long story short, Dany is a subcontracting IT guy for a company who bought the licences. He has asked them to contact their VAR but they do not want to, so he's stuck searching for a needle in a hay stack.
seems like some dll's are missing although you can resolve this problem by repairing your installed program (RMB Solidworks in control panel and click change)
but clean uninstall is always recommended
not necessary in this case but For precaution first note down your serial key for solidworks products then deactivate your serial key -> clean the registry entries for Solidworks from system registry (Do not do this if you are not familiar with editing registries) -> do a fresh installation.
sometimes it happens, check this location (C:\ProgramData\SOLIDWORKS\SOLIDWORKS 2018\templates) your default templates are not present here. I have attached the default templates (will work with Solidworks 2017 onwards) extract and place place them in above mentioned location. If the templates are present there check these settings
Keep the "always..." button cheeked these settings are required for importing other format files when solidworks does not prompt to select template.
Sumit
