"Revision" option not available when right clicking revision table
I'm trying to add a revision table with a couple revisions. I can add the table, but when I right click the table to add a revision the "Revision" option is not shown and I can't add revisions. Anyone experiencing this? Any suggestions?
Thank you,
Andre
Answers 8
JB
JB 2014-01-28 Best Answer
The revision options are, by default, shown only on the first revision table placed in the drawing.  Aside of that one, you get the options to manually insert and remove rows.
You can change that by going to Options:Document Properties:Tables:Revision and selecting a different option in the radio controls at the bottom:
These settings are saved in the document, so if you want to make the changes default for new documents, edit this setting in each of your drawing templates.
If you're talking about a one time issue, where you can't update the table on the lead sheet, then delete all of the revision tables in the drawing and then re-insert the master table on the lead sheet.
Good luck
John
comment imagecomment image
SF
SF 2014-01-28
Thank you John!
I changed them to indendent and it resolved the issue.
RT
RT 2014-02-17
John,
I'm having the same issue since installing 2014 SP2.0. I've tried your solutions to no avail.  I've tried deleting the table and recreating and using all three multi-sheet options.
One thing I just noticed is that the System Options ->Custom property used as Revision is blank.  And my only option in the pull down is PunchID.  Could these issues be related?
FYI I upgraded my 2013 install rather than clean install.
JB
JB 2014-02-17
Robert, it sounds like your pathing on your upgraded install got messed up and as a result, SolidWorks can't find the 'Properties.txt" file which is where that list of Revision fields comes from.  If SolidWorks has lost the connection to that file, then you'll probably have issues with hole callouts, sheet formats and templates.
I suggest looking at your search paths in System Options: File Locations and make sure that everything is pointing to your SolidWorks 2014 resources.
In general, when I upgrade a major version, I do a clean install beside the previous release, migrate the configuration files and settings and then uninstall the previous release.
John
RT
RT 2014-02-17
All the paths in System Options->File Locations were carried over properly.  However, the properties.txt file was overwritten with one that only contained "PunchID".  I updated that file to include all our previous custom properties.  Still have the problem.  I'll keep digging.
RT
RT 2014-02-17
More info.
I get the revision option on the very first drawing I open after I start SolidWorks.  If I add a revision or edit Document Properties->Tables->Revision, the option goes away.  It does not come back if I close the drawing without saving and reopen.  I have to restart SolidWorks to have the option show in the right click menu again.  It doesn't matter what the document properties for multisheet revision setting is.
ML
ML 2014-02-18
Robert,
At this point, I recommend contacting your VAR to have your settings and files looked at.
RT
RT 2014-02-20
I worked with my VAR to fix this.  Apparently it has something to do with menu customization.
  1. Save settings using Copy Settings Wizard
  2. Verify SolidWorks is closed
  3. Clear registry
    1. rename HKEY_CURRENT_USER\Software\SolidWorks to HKEY_CURRENT_USER\Software\SolidWorks_old
  4. Restore settings using Copy Settings Wizard
    1. Uncheck "Menu"
  5. Run SolidWorks
