Hello, I’m trying to troubleshoot an issue. I’ve offset an edge using a distance parameter, but I’ve realized that sometimes the offset extends outside the face, which is problematic because I need to perform an operation (extrude cut) on the face. I attempted a different method, but it doesn’t seem to be working as expected (offsetSign but the value of offsetDistance doesn't change).
Any assistance would be greatly appreciated. Thank you!
'usual variable declarations
' Get the face normal
swFaceNormal = swFace.Normal
' Determine the offset direction based on the normal
If swFaceNormal(2) < 0 Then
offsetSign = -1 ' Reverse offset direction if the normal is negative
Else
offsetSign = 1 ' Use positive offset direction
End If
' Adjust offsetDistance based on the normal's direction
offsetDistance = offsetDistance * offsetSign
' Select and project the longest edge into the sketch
swLongestEdge.Select4 True, swSelectData
boolstatus = swSketchMgr.SketchUseEdge3(False, True)
' Use the part file name for engraving
Dim strEngrave As String
strEngrave = partFileName
Debug.Print "engraving to add : " & strEngrave
' Get the active sketch
Set swSketch = swSketchMgr.ActiveSketch
If Not swSketch Is Nothing Then
' Get all sketch segments
swSketchSegs = swSketch.GetSketchSegments
' Select the last added segment (assuming it's the projection)
If Not IsEmpty(swSketchSegs) Then
Set swSegment = swSketchSegs(UBound(swSketchSegs))
swSegment.Select4 False, Nothing
End If
End If
' Offset the projected sketch segment with the calculated offset distance
swSketchMgr.SketchOffset2 offsetDistance, False, False, swSkOffsetCapEndType_e.swSkOffsetNoCaps, swSkOffsetMakeConstructionType_e.swSkOffsetMakeOffsConstruction, False
