Replace specific text (not Search/Replace)??
I have several pieces of text in a title block that I want to change.
I tried doing a record macro and it doesn't do it completely.
When I run the macro, I see it touch each piece of text in succession so
I am part way there. (Trying a different method than the search/replace
because I cannot assume the text value I am replacing is constant.)
I do know what it needs to be though...
I am looking into how to do a 'DoReplaceString strNote01.. for each item (boolstatus = item lines below)
that I want changed but do not know how to incorporate that function into my code.
(Admitting to being a total novice-wannabe-newbie programmer)
I am as interested in learning how to do this as much as getting it to work...
This is what I recorded and edited.
Adding my variables (the "mytext1" items will be replaced with the actual text I am to use of course)
Am I close or way off here?
Any help is appreciated!!
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Dim longstatus As Long, longwarnings As Long
Dim strNote01 As String = "mytext1"
Dim strNote02 As String = "mytext2"
Dim strNote03 As String = "mytext3"
Dim strNote04 As String = "mytext4"
Dim strNote05 As String = "mytext5"
Sub main()
Set swApp = _
Application.SldWorks
Set Part = swApp.ActiveDoc
boolstatus = Part.Extension.SelectByID2("Sheet1", "SHEET", 0.544872734994015, 6.84439369661325E-02, 0, False, 0, Nothing, 0)
Part.EditTemplate
Part.EditSketch
Part.ClearSelection2 True
boolstatus = Part.Extension.SelectByID2("DetailItem2173@Sheet Format11", "NOTE", 0.551409013785214, 7.55404682251479E-02, 0, False, 0, Nothing, 0)
'Hoping I can replace the text selected here with my "mytext" item....
boolstatus = Part.Extension.SelectByID2("DetailItem2172@Sheet Format11", "NOTE", 0.552529518720848, 6.84439369661325E-02, 0, False, 0, Nothing, 0)
boolstatus = Part.Extension.SelectByID2("DetailItem2171@Sheet Format11", "NOTE", 0.555144030237327, 6.09739040619058E-02, 0, False, 0, Nothing, 0)
boolstatus = Part.Extension.SelectByID2("DetailItem2170@Sheet Format11", "NOTE", 0.542258223477536, 5.68653859645811E-02, 0, False, 0, Nothing, 0)
boolstatus = Part.Extension.SelectByID2("DetailItem2164@Sheet Format11", "NOTE", 0.57269860756226, 3.33347823162669E-02, 0, False, 0, Nothing, 0)
Part.EditSheet
Part.EditSketch
'Part.ViewZoomtofit2
End Sub
SolidworksApi macros
