Hi everyone, I'm simulating the mechanism of an AR-15 rifle in SW Motion Analysis 2013 SP4 on a fast university computer (3.04GHz i7, eight cores, 8Gb RAM...). The model is fairly complicated, but after applying all desired mates, I can slide the bolt carrier back and forth, rotate and slide the bolt along/about its long axis, and move the buffer back and forth in the assembly view. In motion, I'm first attempting a simulation of the bolt being locked (lugs pressed against the barrel extension, therefore the bolt should not move) with a force applied to the bolt face and a contact between the bolt and bolt extension, (just to make sure everything works before going to the trouble of setting up a more complicated motion study). The events in an AR's firing cycle are timed in small fractions of a second, so my simulation lasts for ~26ms with 25,000fps. Looking at the mates list in the motion study view, I see '0 redundancies'; however, when I attempt to run this simulation, I get the following error:
"Initial Conditions Error:
The model contains incompatible redundant constraints, i.e., constraints
that are contradictory and cannot be simultaneously satisfied. Suggested course of action:
Try to eliminate some or all of the redundant constraints in your model."
I then went into the simulation options window and chose 'replace redundant mates with bushings'. I got the following error when I tried to run it:
| Errors found parsing command. Command ignored. |
Simulation can not continue." |
I've searched the web for any explanation of these problems, but no luck.
The model is so large I'm going to upload 2 ZIP files; if you want to see it, just extract both into the same directory and then open "Rifle.SLDASM".
Thanks in advance!
SolidworksMotion Studies
Second ZIP file:
Haven't had a Chance to look at your model.
Do you need to simulate or do you just need an animation?
If animation, go with animation, not motion.
Second, redundancies only show after solving is started. What does it show afterwards?
Before starting this sim, did you simplify the model? Did you try something simple like a gravity study? These are techniques we Tach in our training because at least it gives you a gauge for the model. Then as you add things, you know what caused the problems.
Hi Jared, no, I need a full-fledged motion study. Eventually, I'm going to simulate the gun's recoil motion so I can calculate how recoil changes with modifications.
Good point re: redundancies after solving starts. Then, it shows 48.
I did simplify it with lock joints and suppressing certain parts. I'm going to try rebuilding the assy. and merging parts to further simplify it. I'll simulate every step of the way and see where redundancies start.
nice. good luck. don't hesitate to drop me a line if you need someone to check it over. we also offer both classroom and one-on-one training on motion if you get down to needing some direct help.
I was able to get the simulation to run when I went through the mates and deleted one that was based on sketch elements on different parts (eg. each sketch had a line fixed to its respective part, and the sketch lines were mated to be parallel). I have used such mates in other motion studies for other projects, however, so perhaps it was the complexity of the model that caused these errors. Note that I tried importing the model into ADAMS (despite its nightmarish interface), but this mate caused the ADAMS simulation to fail as well.
