Program crashing when starting or opening a part, assembly, or drawing
Brand new laptop connected to a extra monitor. This problem only occurs when connected to the extra monitor. Recently updated Windows 10 to version 10.0.18362. After the update, Solidworks crashes after I try to start or open a part, assembly, or drawing.
Intel UHD P630 running drivers 25.20.100.6793 and Quadro P2000 running drivers 25.21.14.1735. I've already verified that all drivers are up to date.
I have found that I can get Solidworks to function properly if I disable the Intel graphics device and then re-enable it. After doing this, I can start Solidworks and use it normally.
Coworker with the exact same computer and drivers as me, BUT is on the previous version of Windows 10 does not have this issue.
SolidworksGeneral
Answers 2
DE
DE 2021-04-09 Best Answer
In the Nvidia control panel make sure it is set to use the Quadro for Solidworks. This may not be the issue, but it is something to check and make sure.
DR
DR 2021-04-09
I've verified that the Nvidia control panel points to the Quadro card. Image below is the current setting.
Another bit of information: I have Solidworks 2018, 2017, and 2016 installed on my computer. The RX tool for 2018 lists the Quadro as the graphics card model, but both 2017 and 2016 list the Intel UHD P630. (Listed below are RX 2018, 2017, and 2016 respectively).
comment imagecomment imagecomment imagecomment imagecomment imagecomment imagecomment imagecomment image
