In a weldment part, I have four selection boxes on a property manager page.
The programming context is a VB.Net add-in.
The intent is to load all four boxes via the API. After the inital load, the user may click on any box to put the selection focus there, then click on an entity in the graphics area to load it into the selection box.
I have several problems.
1. When the program selects into Box 1, without touching any other box, Box 2 and Box 4 are also loaded with the same entity that was selected into Box 1. This is especially strange because Box 2 and Box 4 are filtered to receive dimensions only, and the selection in Box 1 is not a dimension.
The behaviors below occur apart from the program; at the property manager handler does not react to selections in Box 2, Box 3 or Box 4.
2. When the selection focus is on Box 2, and the user clicks on a dimension, the selected dimension appears in Box 2 and also in Box 1 (which is filtered not to accept dimensions), and also is added to Box 4, even though Box 4 is set to accept a single item only.
3. When the selection focus is on Box 3, and the user clicks on a dimension, the selected dimension appears in Box 3; Box 1 is cleared; Box 2 is cleared; the selected dimension is added to Box 4.
3. When the selection focus is on Box 4, and the user clicks on a dimension, the selected dimension appears in all four Boxes.
Here is the code which creates the selection boxes:
'BOX 1
ReDim filters(3)
filters(0) = swSelectType_e.swSelBODYFEATURES
filters(1) = swSelectType_e.swSelFACES
filters(2) = swSelectType_e.swSelSOLIDBODIES
filters(3) = swSelectType_e.swSelSUBWELDFOLDER
filterObj = filters
iControlType = swPropertyManagerPageControlType_e.swControlType_Selectionbox
sCaption = ""
iOptions = swAddControlOptions_e.swControlOptions_Visible + swAddControlOptions_e.swControlOptions_Enabled + swAddControlOptions_e.swControlOptions_SmallGapAbove
sTip = "Select Cutlist Item, Body (from Tree), Face, or Feature (from Tree)"
pm_ItemSelection = pm_Page.AddControl(id_ItemSelection, iControlType, sCaption, iAlignment, iOptions, sTip)
pm_ItemSelection.SingleEntityOnly = True
pm_ItemSelection.AllowMultipleSelectOfSameEntity = False
pm_ItemSelection.AllowSelectInMultipleBoxes = False
pm_ItemSelection.Mark = id_ItemSelection
pm_ItemSelection.Height = 16
pm_ItemSelection.SetSelectionFilters(filterObj)
' All remaining selection boxes are for dimension only.
ReDim filters(0)
filters(0) = swSelectType_e.swSelDIMENSIONS
filterObj = filters
'BOX 2
' Thickness selection
sCaption = ""
sTip = "Click on a dimension"
pm_ThickSelection = pm_Page.AddControl(id_ThickSelection, iControlType, sCaption, iAlignment, iOptions, sTip)
pm_ThickSelection.SingleEntityOnly = True
pm_ThickSelection.AllowMultipleSelectOfSameEntity = False
pm_ThickSelection.AllowSelectInMultipleBoxes = False
pm_ThickSelection.Mark = id_ThickSelection
pm_ThickSelection.Height = 16
pm_ThickSelection.SetSelectionFilters(filterObj)
'BOX 3
' Width selection
sCaption = ""
pm_WidthSelection = pm_Page.AddControl(id_WidthSelection, iControlType, sCaption, iAlignment, iOptions, sTip)
pm_WidthSelection.SingleEntityOnly = True
pm_WidthSelection.AllowMultipleSelectOfSameEntity = False
pm_WidthSelection.AllowSelectInMultipleBoxes = False
pm_WidthSelection.Mark = id_WidthSelection
pm_WidthSelection.Height = 16
pm_WidthSelection.SetSelectionFilters(filterObj)
'BOX 4
' Length selection
sCaption = ""
pm_LengthSelection = pm_Page.AddControl(id_LengthSelection, iControlType, sCaption, iAlignment, iOptions, sTip)
pm_LengthSelection.SingleEntityOnly = True
pm_LengthSelection.AllowMultipleSelectOfSameEntity = False
pm_LengthSelection.AllowSelectInMultipleBoxes = False
pm_LengthSelection.Mark = id_LengthSelection
pm_LengthSelection.Height = 16
pm_LengthSelection.SetSelectionFilters(filterObj)
'Here is the callback for the selection boxes.
Public Sub OnSelectionboxListChanged(ByVal Id As Integer, ByVal Count As Integer) Implements SolidWorks.Interop.swpublished.IPropertyManagerPage2Handler7.OnSelectionboxListChanged
If Not nInitComplete Then
Exit Sub
End If
' Selecting to a selection box in ItemDisplayUpdate triggers a recursive callback to this procedure--ignore it.
If nSelectionCallbackActive Then
Exit Sub
End If
nSelectionCallbackActive = True
Try
If Count < 1 Then
Exit Sub
End If
Select Case Id
Case id_ItemSelection ' reacts to a click in Box 1 only.
ItemFolderSelectionHandle()
ItemDisplayUpdate()
End Select
Catch ex As Exception
Finally
nSelectionCallbackActive = False
End Try
End Sub
Any ideas on how to stop the weirdness?
SolidworksApi macros
