I've just upgraded to 2012 SP1 and have noticed a recurring problem with the Rigid/Flexible properties in an assembly. The file was created in SW2011 and then re-saved in 2012. When accessing the configuration in the assembly which has the flexible option highlighted, the assembly and all its parts disappear from view. They show in the feature tree as neither hidden or surpressed. In addition however, the configuration itself appears as suppressed (grayed out) but is not?!? I can delete the configuration and set it up again repeating the flexible properties but I have several assemblies with a configuration of this nature and obvioulsly don't want to have to do this everytime.
Has anyone experienced this or am I just dealing with some corrupted files?
Cheers, Carl.
SolidworksAssemblies
Carl, it would be hard to comment anything without looking at the files. Any chance if you can share files or pictures. In case you can share files, please report this to your VAR. Also can you test the same thing on a different machine.
Hi Carl,
Do you happen to have a file set in the 2011 file format and the steps needed to get the issue to happen with those files in 2012 that you could provide?
Kind Regards,
Julian Galgoczy
