I have a sheet metal part 200mm wide x 1800mm diameter 0.75mm thk. The part has slots (done with hole wizard), 2 rows, and a relief in the middle. all of these features were put in on the flat pattern. Two problems are appearing. First the features become suppressed when the part is folded. Second, center marks cant be put on the slots in the detail drawing. Any help on both or at least the second issue is much appreciated.
-Mark
SolidworksSheet Metal
You need to Un-Fold your part right after the Base Flange1 then add your cuts and then Re-Fold just before Flat Pattern
You can use a construction line for the centerline
Hover over the end slot
Then back off a little ways from the part (see the little + that is a coincident relation to the center of the slot
Then drop the line
Short or long line
Couple of issues. First, I cant unfold the model as it has no flat face. Second, on the slots I can add the horizontal centerlines, but not the cross hairs I desire.
To un-fold select the end of the pc - one of the four edges and then collect all bends - As for the crosshairs - you will need to draw them in unless you use the hole centerline crosshair then it will have two crosshairs per slot .
Unfortunately they arnt selectable due to how the geometry was created.
I first made a 1600mm circle, and then trimmed a small piece from it 0.063 degrees inclusive. I then added a short line to the end of the 1600mm dia curve to create the "flat".
I was able to unfold from that small flat flange. all seems to work now as it should. Center marks and all.
