I ran into an impasse with getting a high quality print using2009. I have a 10 sheet drawing with multiple assemblies andsubassemblies which resulted in the drawing file to be almost 68MB.I switched from using 2008 sp5 to 2009 sp3 not too long ago and Iused to be able to print the drawing in high quality using the samemachine. Now with 2009, I can't get the drawing to print properly,even if I did each sheet individually. SW crashes because it'sunable to obtain required memory. If I do manage to get the sheetto print, on certain sheets, only about 10% is produced and therest is blank. I've exhausted all methods I can think of, includingsaving as a different file (like PDF or eDrawing) because thetables I have in the drawing change size on their own after saving.
I'm pretty sure my hardware is the culprit, but since I was able toprint the same drawings in high quality using 2008 on the samehardware, I feel 2009 is to blame as well. Any suggestions on how Ican get around this?
SW 2009 sp3
Windows XP32
Dell Latitude D830
Intel Core2 Duo T9500 @ 2.60GHz x2
2GB RAM
NVIDIA Quadro NVS 140M
SW 2009 sp3
Windows XP32
Dell Latitude D830
2GB RAM
If the system is saying you are out of memory, beleive it.Especially with only 2 gigs of memory and the huge drawing you aretrying to print.
You are also using a non approved graphics card for SW. Getyourself an approved card and life will be better.
Yes, it does make a difference with SW what your hardware is.
Just because it work in SW2008 with inadequate hardware doesn'tmean SW2009 will work too. New versions of SW will push thehardware envelope further. You have stepped over the edge.
Cheers,
Thanks for your advice though, Anna!
