Problem with knitting linear pattern as a feature
I am trying to create a parametric model of our main production part. It is being constructed as a surface, with a linear pattern feature adding repetitive segments in the middle. I would like to be able to apply a knit to the entire linear pattern, irregardless of the addition or removel of segments. However, I cannot select the linear pattern as a feature through the knit menu.
Currently my only path is to clear all of the old selections of the knit, and left click>drag a selection window over the entire collection of surfaces. There are a few other paths to individually select each linear pattern segment that I have come across, but nothing allows me to simply select the linear pattern as a feature, and thereby bypass the need to select each linear pattern segment in some manner.
In the attached picture, I am trying to select the "FULLCNVLINPAT" linear pattern feature. I can select the 3 surface revolves and the mirrored surface from the feature tree, but I cannot click on the linear pattern feature.
SolidworksSurfacing
Answers 10
JF
JF 2014-03-20 Best Answer
I don't know of a direct way to select that linear pattern, but maybe this would be one of the few times it would be worth doing it as a sketch pattern instead of a feature pattern?
SF
SF 2014-03-20
Jeremy,
I tried doing that, but I cannot place a parametric dimension controlling pitch in a sketch. From my investigations, there is not a way to do it within the sketch. I currently have parametric dimensions controlling pitch and quantity in the linear pattern feature, a level of control I was unable to reach inside the sketch.
JF
JF 2014-03-21
do you have these two checked when making the sketch pattern? they should put the spacing (pitch) and instance count as dimensions into the sketch.
comment imagecomment image
SF
SF 2014-03-21
Jeremy,
That allows me to parameritize the sketch, but I am unable to select the full convolution revolve feature that I was previously able to select (when there was a single revolve without the linear sketch pattern). It seems that the addition of a linear pattern, either inside a sketch or as a feature, prevents the knit from selecting the feature.
In short, it moves the linear pattern, but does not change my problem. I was not aware of the display instance/spacing control before.
JF
JF 2014-03-21
weird - it seems that the knit feature will not let you select (by feature name) any feature that creates more than one surface body.
SF
SF 2014-03-21
I would agree that that is the problem. If I cannot correct that, then I have 2-4 manually applied re-knit steps in an otherwise completely automated parametric model.
SF
SF 2014-03-24
Jeremy,
I just updated to SW 2014 from SW 2013. No change to the Knit patterned feature issue. Do you know of any other possible paths forward?
JF
JF 2014-03-24
there may be some way to redo the sketch so that it generates a single surface body, but I can't investigate that without your part file and requirements for the parameterization. and I am on 2012.
have you asked your VAR for ideas?
SF
SF 2014-03-24
I have pursued a solution with my VAR. They are currently experimenting with the part file to find a solution, but so far have investigated the same paths that you have suggested.
SF
SF 2014-03-26
To experiment with that would take a significant restructuring of my part. The surface has limitations in that it still needs to be knitted to be thickened later. A surface generated by a sketch linear pattern still shows each segment as if it was a feature linear pattern, even if it wasnt generated by one, and this prevents the thicken feature from applying to the target surfaces. In short, I still need to knit the surfaces even if it was generated by one surface revolve, as long as there is a linear pattern of a sketch or a feature.
