I'm beginner in SW and I don't know very well flow simulation so I explain my problem
I have build a tank storage with an inlet and an outlet and I want to smiluate a flow of water through the cylinder tank
But I did the different tutorial of FS and I don't know how I can impose that there is a fluid (water) in the storage tank
I've tried to create lids in the inlet and the outlet but it don't understand that I want a fluid in the tank.
In the tutorial, th've already create an enclosure so I think that it could help me but I don't how it will be create ??
Please can you help me in easy english...Thx
PS : if you want more details, contact me, there is no pbm !
SolidworksFlow Simulation
In addition, on the Flow Sim tree, under Input Data, is the subheading 'Fluid Subdomains'. Pick one of your lids, and select the inside surface of the lid. The click on Fluid Subdomains, right click Insert. You can then define what fluid you want and it will show you the fluid volume.
Cheers, Rich.
I just want to thanks you for your fast answer and your help was very interesting, I should work more to find the solution because geometry is very complex in my problem, and I will tell you if I reach to simulate my flow.
If anybody have some others lead to help me no doubt
Thanks
Hello
I try to do flow simulation with enclosure and heatsink with heatsource. I want to consider enclosure wall with constant temperature of 25 C and heat source of total 10 W. and heat sink attached to heat source. heatsource and heatsink assembly keep in the middle of enclosure in vertical position. I want to get temp distribution through natural convection on heat sink surfaces as it keep vertically.
Any one can help me, how to apply boundary condition in this case for wall temp. and also natural convection for heat sink.
I attached assembly of it.
help?
