I've been following very specific instructions to make a car jack (scissor jack) assembly. At this stage, I should be able to spin the crank handle by clicking and dragging - however, I can't. Unsure where I'm going wrong as I've checked and re-assembled many times according to the instructions. Crank handle is mated so that it is aligned with the lead screw and parallel with the right plane of the assembly so that it can spin in one axis only. If anyone has time to take a quick look and suggest where it is I'm going wrong, I would be very grateful.
SolidworksAssemblies
Hi Enya,
Great model. Straight from opening the assembly I can spin the handle no problem.
Sometimes lack of movement can be that your system can't compute the mates as fast as you want to move it. Is your hardware SW certified?
Who has been giving you these instructions? One reason this is giving you fits in SolidWorks is that the design is incorrect. A jack designed like this is absolutely non functional. To keep it from flopping all over the place in SW, you have to add mates that are not supported by the mechanism itself. Look at a real jack. The upper and lower plates have meshing gear teeth to force them to rotate at the same rate. The pin joints where the jackscrew goes through are a shared pivot point for the upper and lower arms rather than separate pivots as in your model. With separate pivot points, there is nothing keeping the nut portion from twisting and putting an incredible moment on the jackscrew, which will bind up or bend.
That makes sense, thank you Heiko for explaining, I'll give it a try with some additional mates and get rid of the problematic one
But the "dancing" movement is part of the reality, and also a part of the problem in SWX...
If you don't want it to dance, than add some additional mates to avoid this. But to keep the crank parallel to the other plane (as before) is no good solution...
Hi Enya,
I was more referring to your hardware. What graphics card are you running for instance?
https://www.solidworks.com/support/system-requirements
Hello Heiko,
Thank you for investigating! I have tried your suggestion and it may be a fix - however the jack starts to dance around quite a lot and doesn't only move up and down with this method - I'll have to keep thinking
Hi Bjorn,
Thank you very much for taking a look! I have the latest educational license from my university - is there something I should check in my install that might make a difference do you think?
If you supress the Parallel6 mate it will be possible to move your components.
As you can see, there is a lot of movement possible. This is hard for SWX to calculate in realtime.
It'll be better, if you change this mate to another face:
