there is a flat face on to.sldprt i select that face and coincide with point during recording a macro but when i run the macro it is not selecting the right face.
in image 1 the face is selected that i need but in image 2 the face is selected that is not my requirement
SolidworksApi macros
From your image 1 it is not clear as which face you want to select via macro.
If it is possible change to.SLDPRT so, that flat face is on origin.
Here is your macro - cleaned up from unnecessary code.
Option Explicit
Dim Part As SldWorks.PartDoc
Dim boolstatus As Boolean
Dim longstatus As Long, longwarnings As Long
Sub main()
Set Part = swApp.ActiveDoc
Dim myFeature As SldWorks.Feature
Set myFeature = Part.InsertPart2("........\wo.SLDPRT", 1109)
Part.ClearSelection2 True
Part.SketchManager.Insert3DSketch True
Dim skPoint As SldWorks.SketchPoint
Set skPoint = Part.SketchManager.CreatePoint(-0.019544, 0.024943, -0#)
Dim skSegment As SldWorks.SketchSegment
Set skSegment = Part.SketchManager.CreateLine(0.0005, 0.0005, -0.0055, -0.045682, -0.052104, -0.0055)
Part.SetPickMode
Part.SketchManager.InsertSketch True
Set myFeature = Part.InsertPart2("........ \to.SLDPRT", 1109)
Part.EditRebuild
Dim Component As SldWorks.Component2
Dim FeatureData As SldWorks.MoveCopyBodyFeatureData
Dim swFeat As SldWorks.Feature
boolstatus = myFeature.Select2(False, 0)
Set swFeat = Part.FeatureManager.InsertMoveCopyBody2(0, 0, 0, 0, 0, 0, 0, 0, 0, 0, False, 1)
Set FeatureData = swFeat.GetDefinition()
boolstatus = Part.Extension.SelectByID2("Axis1-to", "AXIS", 0, 0, 0, False, 1, Nothing, 0)
boolstatus = Part.Extension.SelectByID2("Line1@3DSketch1", "EXTSKETCHSEGMENT", 0, 0, 0, True, 1, Nothing, 0)
FeatureData.AddMate Nothing, 0, 1, 0, 0, longstatus
boolstatus = Part.Extension.SelectByID2("", "FACE", 0, 0, 0, False, 1, Nothing, 0)
boolstatus = Part.Extension.SelectByID2("Point1@3DSketch1", "EXTSKETCHPOINT", 0.0005, 0.0005, -0.0055, True, 1, Nothing, 0)
FeatureData.AddMate Nothing, 0, 2, 0, 0, longstatus
swFeat.ModifyDefinition FeatureData, Part, Component
End Sub
Selection using coordinates is very unstable in the API. Selections will vary depending on zoom level and model rotation. I'm not really sure what your process is for building the parts, but if you can give your face a name, it will make selection much more reliable.
To name your face, you can right click on it and select "Face Properties" (may require expanding the menu). Then you can enter a name in the window.
