Problem getting Material Properties on a component in an Assembly
I’m having some trouble with some code that I’m writing to assign colors to components in an assembly.  Sometimes swMaterialProps returns nothing from the swComponent.MaterialPropertyValues call. But this is happening completely randomly. Sometimes the call returns a value for a part and sometimes it doesn't for the same part.
Case swDocumentTypes_e.swDocASSEMBLY
                Dim clsSelectionManager As swSelectionManager = New swSelectionManager
                Dim swAssemblyDoc As AssemblyDoc = swModel
                If clsSelectionManager.IsSelection(swApp) Then
                    'Change color on selected components
                Else
                    'Change color on all components
                    Try
                        Dim objComponents() As Object = swAssemblyDoc.GetComponents(True)
                        For Each objComponent As Object In objComponents
                            Dim swComponent As Component2 = objComponent
                            Dim swMaterialProps As Object = swComponent.MaterialPropertyValues
                            Dim j As Double = 0
                            If Not swMaterialProps Is Nothing Then
                                Debug.Print(swComponent.Name2 & " before color change")
                                Debug.Print("  " & swMaterialProps(0))
                                Debug.Print("  " & swMaterialProps(1))
                                Debug.Print("  " & swMaterialProps(2))
                                Do Until j > 0.3 And j < 2.7
                                    j = 0
                                    For i = 0 To 2
                                        swMaterialProps(i) = clsRandom.NextDouble
                                        j = swMaterialProps(i) + j
                                    Next
                                Loop
                                Debug.Print(swComponent.Name2 & " after color change")
                                swComponent.MaterialPropertyValues = swMaterialProps
                            Else
                                MsgBox("Unable to change color for " & swComponent.Name2)
                            End If
                            swComponent = Nothing
                            swMaterialProps = Nothing
                        Next
                    Catch ex As Exception
                        MsgBox("subRandomColor(All parts in Assembly): " & ex.Message, MsgBoxStyle.Critical, "Error")
                        Dim errorlog As New ErrorLog
                        errorlog.SendErrorToLogFile(swModel.GetPathName, clsCC.strUserInitials(), Format(Now, "short date"), ex.Message, ex.StackTrace)
                    End Try
                End If
        End Select
SolidworksApi macros
