Hi all,
When I print a solidworks drawing to smaller paper size, the line thickness stays the same. So when I print a A0 size drawing on a A4 paper everything will be a black blur. Is there a way to scale the line thickness according to the paper scaling? This was never a problem in any other CAD programs I worked with.
Thanks,
Arie van Gelderen
Yes, go to Tools=>Options=>Document Properties=>Line Thickness. The only other way to draw to scale is to scale to page size in printer properties.
Thanks Richard,
When I send a big A0 drawing to the designjet printer and scale it to A4 size all line thicknesses are two times smaller. Thats OK.
The problem is that most departments in our company have only A3 or A4 laser printers. When I select such a printer the maximum paper size I can select in the page setup is A3 or A4. So solidworks seem to think it's a A3 or A4 drawing and doesn't scale the line widths when you print it.
I would check to see if there is a control in the printer software (printer properties?) to allow this change to take place.
Save as full-size TIF or PDF, then print the TIF/PDF.
I think you are right, Jeff.
In the current driver software of our Kyocera KM-4050 I can only specify the paper size and not the original size. On the Designjet I can specify both. So I think it's a driver problem.
