Please help with installation Issue
When Installing Solidworks 2012 on my computer, I keep receiving this error. I have attached the logs below. Would you please be able to help me out?
SolidworksGeneral
Answers 7
AW
AW 2013-10-29 Best Answer
Andrew,
You will want to remove your log files from the forum.  They contain your SW serial number.
Is this a commercial or educational seat of SW?
Post image files of the error you are seeing on screen.
Cheers,
Anna
SF
SF 2013-10-29
This is a student edition of SW 2012-2013 edition.
JM
JM 2013-10-29
What is the error (without including personal information)?
I recommend installing with anti-virus and UAC temporarily disabled.
What is your OS?  (Windows 7, 8? 32-bit? 64-bit?)
SF
SF 2013-10-29
My operating system is Windows 7 Professional 32 bit. One error code I am getting is Vsta. and there is another one, but now I am having the vsta error again
JM
JM 2013-10-29
Windows 7 32-bit would indicate a very very very old machine.
Are you sure your OS is 32-bit?  How much RAM do you have on this old machine?  Have you reformatted the HDD to clean it up in the past year?
What are the Vista errors exactly?
SF
SF 2013-10-29
My computer is not very old, its only 3 years old at this point. It has always had windows 7 on it. I have not reformatted it in the last year. I had solidworks on here about 6 months ago and my computer crashed. After i reinstalled windows 7 professional on it, I was able to install it, but it did not run completely like it should so i uninstalled it because I did not really need it. I need to reinstall it now for a project. The file named windowsinstaller-kb893803-v2-x86 will not run at all so maybe this file is bad?
JM
JM 2013-10-29
<p>Andrew Lepkowski wrote:</p><p></p><p>My computer is not very old, its only 3 years old at this point....</p>
How did you come to the conclusion that it has 32-bit version of Windows 7 installed?  (also, you didn't answer my question about RAM)
Go the Windows Start globe in lower left corner of screen and click on it.
Then right click on Computer and go to Properties.
What does Properties report as your version of Windows 7 (32-bit or 64-bit)?
How much RAM?
Here is an example - you should see something similar...
comment imagecomment image
