I downloaded a some parts from Colder and the parts were in for form of macros that drew the part. I am trying to clean-up the parts. They will become library parts in most cases.
The planes were without a way to change or define like a default planes. So, I cannot tell if the plane is under defined as I don't see an "Edit Feature" definition.
How do you make a plane without a edit feature and is it under defined?
How to change is there some toggle to make editable? For example plane 3 in the file.
For my file example: I was able to replace most planes with default planes or surfaces. Except plane 3, I added plane 7 to show you an edible plane like I normally make.
I also notice some planes were parallel to a default plane but the feature direction was reversed. Maybe not in this file but other ones.
SolidworksImport export
that is just bizarre...
since this was made from a macro, you may want to ask in the api section - they might know what is going on in there.
since this is a store bought part they may have locked out the planes so you cant do mods to them and this could be done through the api. if you want to mod you would have to make a new plane were needed and then edit the sketch plane to your new plane.
