Placing an axle - Need to know weights in front and behind axle
I have a piece of small land levelling equipment that I am adding an axle to for hauling from one field to the next with a half ton. I would like to put about 70- 80% of the weight on the axle and 20-30% of the weight on the hitch. Is there a way I can add a plane in where the axle sits to determine the weight in front of the axle and the weight behind the axle of this assembly?
SolidworksAssemblies
Answers 6
GS
GS 2011-01-10 Best Answer
There may be a better way, but you could just cut your assembly off at the plane with an Extruded Cut and edit the plane until the weight gets right according to the Mass Properties, then delete the Cut.
DB
DB 2011-01-10
I had thought of that and dismissed the idea as my experience with assembly level features are they can be very slow; but I did end up trying this and it worked out nicely. Thanks!
SF
SF 2011-01-10
If you want to go a step farther, this might help.
I have attached a macro that will put a 3D sketchpoint at the CG, and will update it at every rebuild of the model.  Then you can insert a plane that is a distance from that point, and controlled by an equation so that it updates that location as you develop your model.  If you want 80% of the weight to be on the axle, then the distance from the hitch to the CG will be 4 times the distance from the CG to the axle.  So the equation would be something like DistToPlane=DistToHitch/4.  That simple.  :-)
  WT
DB
DB 2011-01-10
Thats quite impressive; too bad Solidworks hasnt incorporated that into its program. The assembly level cut extrude worked fine for me: within one iteration I had a number in my tolerances (and the fixture for the axle lined up in a favorable location so I have no need to be more precise.
Thanks for the help
SF
SF 2011-01-10
Wayne,
This macro isnt working for me. Any idea why? It just seems as if nothing happens...
Nick
SF
SF 2011-01-10
The most usual reason for a macro not running is because it can't find a reference file.  Open the macro in the editor and check the references - see if it's missing one or more.  You may not have the referenced versions on your machine.
WT
