Intro:
3 months ago, we went from Solidworks 2021 to SW 2025.
During that time, we also got a new server.
All files are moved to the new server without any problem.
We also moved the cold storage to the new location and SW finds the old files on the new location.
No problem on that side of things
Proplem:
With many of our toolbox components, we couldn't get the latest version.
Many files have a 1/3 version or, say, a 9/12 version.
If we want to retrieve the latest version, the warning is: no check-out rights.
I don't need to check-out a file to get the latest version.
Every time we start-up, PDM retrieves the latest version and we get this pop-up screen:
But no serult on this message.
When finished get latest version and open an assembly, sometimes i get this pop-up screen. But with no result.
It seems I don't have permissions to retrieve the latest version of our toolbox files.
If we do the same as Admin, we get the latest version without any problems.
The next time I log-in as my own user, we have the same problem agian.
Does anybody know a solution to this problem?
For solutions:
We have already searched for valid permissions in the administration tool.
I think it should be there, because of the admin permissions, but I couldn't find the solution yet.
Toolbox PDM Data Management & PDM Get latest versions get latest versions Solidworks PDM 2025
Sounds permission related. Cold store can only be done on older versions, latest version is always available (i.e. cannot be cold stored). But why would "get latest" still fail is the mystery.
I'd recommend you work with your VAR to get this reported to SWPDM technical support for investigation.
@TI It is strange because, as far as we know, the settings have not changed. So what is different between before, when we used 2021, and now. We tried a lot in the administration tool, even with our VAR.
We tried restore the history to previous versions and that hides the problem a bit. It's not the solution I'm looking for. Then I don't know what is missing from our toolbox.
"All files are moved to the new server without any problem. "
Are you 100% sure about this statement?
How were the files moved? Have you checked all the raw files hashes before and after moving?
It is not a task you can do with a copy paste or robocopy script alone and hope it goes well.
There is always the risk files versions could be go corrupted during a server move for multiple reasons and must be validate.
Do not assume your VAR did it as this operation need likely custom tools to be performed.
That said I would check ACL on the file NTFS system to see if new server PDM service has full access to those files or the permissions got messed up during the moving phase.
About the possible lack of permissions, I assume you’ve already run all your tests using the ADMIN user, right?
Unless someone has modified the Admin’s permissions, this user should always have full access to everything (if not, we can fix that, but that’s another story).
Let’s assume the Admin is also experiencing the same issue, has your VAR looked into the database and archive server folders?
That’s where the answer lies, because warning messages can sometimes be misleading.
