part info will not update after 2018 upgrade
After up dating from 2017 to 2018, the part information will not populate correctly, if you enter all the information and save out , when l return to the part the text has vanished!
The only way I can navigate around this problem is to insert text one line at a time, save out , go back in and type next line, save out again, and so on.
This is very tiresome,  as I deal with all lot of individual parts with 12 lines of information a piece.
I have contacted solidworks with this, but have received no solution, the operator was at a loss, to explain why this was occuring.
SolidworksGeneral
Answers 5
CI
CI 2018-01-26 Best Answer
Are these properties you are typing things into that have the problem? It isn't exactly the same, but the description will sometimes go away. I have to register the sldpropertyhandler.dll regularly. Take a look at this Blog and see if any of the changes it mentions help,
How to Fix the Description Field When It Is Missing From the SOLIDWORKS Save As and Open Dialog Box? | Computer Aided Te…
Good luck,
Carrie
SM
SM 2018-01-28
Thanks for your time, i will give this a try first thing Monday morning, one thing I have noticed is that since the update is that the info data entry panel has a small sideways figure of eight ( Infinity symbol ?) , when this is present the problem will not occur , but if i open a part created in Solidworks 2017 it is not there, and this problem persists.
SA
SA 2018-01-28
I do not understand your question.  Can you provide screen shots or model of the issue?  I do not use SW2018 on a regular basis yet and I had only seen the "figure 8" in the cut list properties dialog but I also found it is in the Custom properties dialog (see bleow).  Is this what you are referring too?  Is so, are any of the check boxes checked?  In the example below, I was able update the properties at the same time (but it was a model created in SW2018 and not one created in SW2017).
comment imagecomment imagecomment imagecomment image
SM
SM 2018-01-28
Yes you are indeed right, its the " summary information" ,under the custom tab,  which is giving me the most grief. sorry to mislead you.
SA
SA 2018-01-28
I did some more investigation.
For a part created before SW2018, no link column is displayed (it is not a figure 8, if you look close it is two chain links) when opened in SW2018.  The link column only seems to appear in models created in SW2018.  Again I had no issues updating multiple custom properties and saving them.  My only suggestion (because you have already contacted your VAR) is to upload one of the models you are having problems with.  If you cannot do this due to customer or company policy, blow away all the model's feature and then upload (hopefully you do not have any proprietary information stored in your custom properties.
Screen shot below is of a part created in SW2017 and opened in SW2018 - no link column
Screen shot below is of a new part created in SW2018 - has link column (however it is greyed out and inaccessible on my models).
