Pack and go an assembly with a design table - references are not updated
Hallo,
I want to copy an assembly with pack and go, adding a prefix or suffix to the filenames.
In the design table though, the part names are not updated with the prefix. Thus, the table can't find the referenced part...
Is there any way to add the prefix / suffix in the design table automatically while using pack and go?
Thanks a lot for your help,
Katerina
SolidworksConfigurations design Tables
Answers 5
JS
JS 2016-02-10 Best Answer
I don't think that the design table will update using pack & go, also the configuration name will not update either.  It should be easy to change the names in the design table..
SF
SF 2016-02-10
Hi John, thanks for your reply. It might be easy to change the names in the table, but it is a LOT of names in a LOT of tables, so changing manually is not really an option for us...
JS
JS 2016-02-10
Did you check with your SW reseller VAR?
SF
SF 2016-02-10
Yes, but they didn't know too. They found a bug report with the same problem which was supposedly solved in 2013...
SH
SH 2016-02-10
I've heard of one person saying this did work but I have never seen it.  I'm posting here in case someone does know how to do what your asking cause I would like to know.
I use the folder name the excel sheet is placed in to drive the Design Table formulas.  This is because the Suffix of the files for the pack and go and folder name are both the clients name.  The excel code extracts the last folder the excel design table is in (which is the client's name) and inserts it into a concatenate function for the design table variables.
This only works if you save out a separate Design Table for each assembly which is my work flow for certain projects.
=CONCATENATE("$Configuration@",Sheet2!$A$1,"Table<1>")
returns
$Configuration@AmazonTable<1>
Sheet2!A1
=TRIM(RIGHT(SUBSTITUTE(LEFT(CELL("FILENAME"),FIND("[",CELL("FILENAME"),1)-2),"\",REPT(" ",50)),50))
returns
Amazon
