One way clutch, sprag or ratchet mechanism
I am new in this forum actually this is my first post as you can see.
My question will be short. I have difficulties building a sprag which would let my gears turn in one way only.
What kind of relation or mate should i use in order to make it?  All i need to get one way turning.
Thanks.
SolidworksMotion Studies
Answers 4
SF
SF 2012-07-15 Best Answer
this picture demostrates the gear set. All I need is when small gear turns CW it will make the large one turn in the same direction while small gear turns CCW do not effect the large one at all.
comment imagecomment image
JB
JB 2012-07-15
There is no "one way" mate in SolidWorks.  If you want to show a sprag clutch in an animation you need to suppress and unsuppress the mate used to link the gear to the clutch shaft.  When you want the gear and clutch to to rotate together, you unsuppress the mate, when the clutch rotates opposite, you suppress the mate.
SF
SF 2012-07-17
It may be possible to with the limit angel mate, although you will only have about 1 turn in reverse before it all starts to spin again. Depending on what you are trying to do it may or may not work for your application.
SF
SF 2012-07-18
supressing and unsupressing during motion study, is the only way to get one-way sprag clutch motion. I made it yesterday. thanks to everyone who posted answers here.
