I have a weird thing going on. I am trying to use Normal Cut feature to normalize a beveled cut in a sheet metal part - but for some reason, instead of removing extra material like it normally does, in this part it adds some:
Why does it work like this, and how do I make it remove material instead of add it? I know there are other ways to make this cut, but I need this specific feature because there will be a lot of similar cuts, and Normal Cut is the most convenient feature for this, by far.
Attaching the file.
SolidworksSheet Metal
Your file is 2019 or later…. so I can't open it. But looking at your picture it seems that you have a case where SW normalizes to the maximum amount. Maybe switching the cutting sketch to the other side of your sheet will work.
Can't say really. Would need to see the setup.
Since you are on a 2017 + later Version look into "Insert > Sheet Metal > Normal Cut" and the "optimize geometry" setting in the standard cut feature. They would apply in some of your recent posts and might offer a different approach.
