In part, circular pattern (features) has the following options
-geometry pattern (VERY USEFUL)
-propagate visual properties
-full preview
-partial preview
In assembly, circular pattern has only
I really am in need of the geometry pattern option in the assembly level. Why would it not be available...any ideas...see attached
SolidworksAssemblies
There is no geometry pattern option in the assembly as what you are seeing is the equivalent of a geometry pattern. A geometry pattern option in the assembly wouldn't be useful as it wouldn't do anything. For the preview, I guess they decided to not allow the possibility of turning the preview off.
It wouldn't do anything? I dont follow. See the attached file and how it would be useful, exactly as it is in the part level. If you are attaching a feature (whether at part level or assembly level) to a vertex and then you try to circular pattern it, you are left with what my attached file shows...this is exactly where it would be useful
am i missing something?
Oh you're talking about a feature level pattern in an assembly, not a compononent pattern. That's weird, when I created a pattern it created a geometry pattern and did not allow me to retain the end conditions, but on your part the case is the opposite.
Joel,
Are you saying that if you edit the part file in the context of the assembly the feature patterning is greyed out or just not there at all?
Sorry it took me a while to figure out exactly how the functionality was working out. The preview displays as a geometry pattern (partial preview) but the feature itself follows the end condition. That would be pretty frustrating if you're trying to create this feature in the assembly.
If the hole wizard hole must be created in the assembly, you can use the progagate feature to part option, and then create the pattern within the part using geometry pattern.
Scott,
Circular Pattern has less options if done at assembly level. see attached (circular feature in part has the option i need "geometry pattern, while circular pattern done in assembly does not offer this option...makes no sense)
Rohit,
I do not want the feature to propagate to the part. The actual assembly i am working on is made of 3 parts. I want to have a hole drilled through all three AFTER they are assembled.
See the attached parts. I measured the distance from vertex to the right plane and used an offset from surface from the right plane. Since the right plane is at the center of the part, the geometry is identical for the two patterned holes.
Yes, any manual input will achieve duplicate depths. The work around i found was this
-Annotation dimension to the vertex
-Drive the hole wizard sketch responsible for depth with the annotation...
Achieves the same thing that the check box would have..:)
Clever, I like it. Guess the developers were too lazy to put in the geometry pattern option
Joel,
Have you tried dragging in the option from the customize menu to your toolbar?
Its a check box option with in the cirular pattern feature on parts...is that possible? can you elaborate.
No it is not possible, unless he means that you should drag in the circular pattern feature onto a menu. But that just ends up being the same options as the circular pattern from the pulldown.
Joel,
Sorry, I misunderstood your original question. I was wrong. I don't understand either why these options
aren't there in the assembly as well. This sounds more like an ER should be submitted.
