Hello;
Anyone know why there's no space for the dimension, on my attachment? It makes the dim hard to read, & we'd like to
change it. If I remove the break, the dim has the normal break in the lines where the dim is.
Thanks, in advance for any input;
Rob_D SW 2013 sp3
that looks like a bug.
but have you tried dragging the squiggle to the other side of the dim?
Hello;
Yes I did pull it through the whole area, up & down. If i shut off the break squiggly lines, there's the necessary gap,
but then of course no break lines. There might be some minute angles going on, & maybe SW, is having a hard time
understanding that. I built some things off a customer, model, & then had slight undersirable angles, but I wanted to reproduce
what they had.
Thanks,
Rob_D
ok - one other think you can try would be to re-create that dim by selecting alternate circles or axis. the bug may be tied to the geometry selected for the dim.
I have seen this before in broken views and assumed it was a bug but never reported it as it was not a huge hassle for me. When this occured i always moved the dimension outside the extension lines as it still worked for the look I needed. This hasn't happened in a while so I had just forgotten about it. I would definitely send it to your VAR.
Hello;
Yes, I think it's a buggy thing going on. I first dropped the dim down with spaces, & then did, my own break lines, but after having a few other issues with the view, I just did another ortho view off the front, & then it worked fine. There was only around 1/2 dozen annotations, so it was definitely worth it.
Thank,s
Rob_D
