New system passes every benchmark I can find. Repeatably fails while running flow simulations.
I am out of ideas for what could be wrong with this computer. 9900K, 64GB of 3600Mhz G-Skill RAM, 970 Pro SSD, Gigabyte Master motherboard, P1000 GPU, and 360mm AIO cooler. Prime95, PassMark SSD, Memtest86, Cinebench, and Solidworks benchmark all pass with flying colors.
The issues comes up seemingly randomly while running a flow simulation. "SOLVER TERMINATED ABNORMALLY! Contact support..." It can happen during a refinement or in the middle of a travel. It has happened on simple airfoils made with splines and complex full aircraft geometries. It happens with XMP on or off. Load line calibration up or down for the CPU. None of the temperatures reported to HWiNFO go above 75C on any of the components. It happened on 2019 SP4 and SP5. It continued to happened after reinstall Windows.
There is nothing in the event viewer. There are no indicators or hints that I have found to help me diagnose this machine yet. Are there any logs that can help give me a hint as to why SWFS is struggling to work on this machine?
SolidworksFlow Simulation
Answers 4
RD
RD 2021-04-08 Best Answer
Hi Charlie,
This sort of error would indicate a few things but none of them would have much to do with the hardware in the machine itself.  So, while your machine probably does benchmark very well that has no effect on whether you will have this error or not.  I have seen the error occur in a few situations.  In order of frequency:
  • If the model has a vortex across a pressure boundary you usually get a warning about the vortex then the solver has a possibility of abnormally terminating.  A vortex across a pressure boundary doesn't guarantee an abnormal termination but it can lead to one.  You might want to take steps to alleviate the vortex to lower the possibility of an abnormal termination (GoEngineer - SOLIDWORKS Flow Simulation: How to Handle a Vortex Across a Pressure Boundary | GoEngineer).
  • When a model is constructed with interference between models I have seen this error pop up.  Often interference does not matter in Flow Simulation for a lot of circumstance.  It does matter sometimes though so I have gotten in the habit of just not letting there be any interference in my own designs as a matter of preventing the possibility of this error occurring as a result.  I might suggest you detect and remove any interference you may have in your models (GoEngineer - SOLIDWORKS: Interference Detection).
  • If you are in a situation where you use Free Surface this error might come up from having too coarse of a mesh in the region of the free surface.  In that case the recommended action would be to apply mesh control to that region so there are more cells on the free surface for the solver to use in calculating that interface (GoEngineer - SOLIDWORKS Flow Simulation: Mesh Controls).
  • The last one I can think of has to do with where files are stored.  Sometimes when storing files on a network drive, external drive, or local drive managed by a cloud storage system (like Dropbox) I will see this or  FORTRAN error come up.  In those cases, copy the files locally (or turn off cloud syncing for the cloud storage software) and run them from there.
There are probably some more things that will cause this but these are the ones that come to mind for me.
CJ
CJ 2021-04-08
I'll send our VAR a message and see what they say. Thank you!
CJ
CJ 2021-04-08
I don't think any of these cases apply to this computer in particular. I tried swapping the RAM out and moving the SSD to CPU PCIe lanes and still hit the same issue.
  • There is clean flow without a vortex going to the computational domain borders.
  • It happens in simple spline 2D airfoil shapes and simple extruded wings.
  • Not free surface problems for us
  • Files are store locally in a plain user directory
JS
JS 2021-04-08
There is a chance the same Flow Simulation studies would run without error on another system. If so, hardware could be the root cause, especially if this is a custom-built system with an overclocked CPU. If you are using a commercial license of SOLIDWORKS, you may want to contact your SOLIDWORKS Value Added Reseller (VAR) to investigate further.
You could also test specifying only 1 CPU core in the 'Use __ Core(s)' section of the Flow Simulation Run dialog. Restricting the study to only one core will take longer to reach the same number of iterations, but it will be less likely to trigger hardware problems (thanks to less strain on system resources). Be sure to also check the System Event Log in Event Viewer to look for clues - in particular any entries related to processors.
Beyond that, other customers in such situations typically contact their system vendor to investigate and test the effects of changes to system configuration, for example:
- Disabling overclocking
- Updating the BIOS/firmware
- Running additional motherboard diagnostics
