Need way to make a part configured but only in an assembly
I have a part that has 32 different configurations. Some of the 30 configs have a second layer of configurations (derived config). Each configuration wither top level or derived config has there own unique part number. I am using this part in a new assembly and need a hole (that is turned on in a derived configuration). I want to use this part but the hole needs to have the chamfer on the part be turned off. Is there a way to do this in the assembly so I don't have to make a new derived configuration of a derived config, IE. hole chamfer on/off configuration?
087-1H-160-06-000 is top level part
087-1H-160-06-024 is the same part but with a 1/4" hole in the side with chamfer
087-1H-160-06-A24 is the same part with the 1/4" chamfered hole but at a different location
I don't want to create a new part number to use the 087-1H-160-06-A24 without a chamfer on the hole.
Any suggestions?
Thanks in advance.
SolidworksConfigurations/design Tables
Answers 5
JF
JF 2021-04-08 Best Answer
wouldn't you NEED a new part number to receive the part without the chamfer?
I don't see a way to remove a chamfer at the assembly level. BUT, you could ADD a chamfer in the assembly.
GS
GS 2021-04-08
Frederick Law wrote:
2 different parts with same part number?
You sure?
Insert 087-1H-160-06-A24 in a new part.
"Remove" the chamfer, save it with file name 087-1H-160-06-A24.
Use it in your assembly.
I'm not responsible for any pain and problem caused by this.
...or just save the existing Part as a new name, delete the chamfer feature, and use it in the Assembly.  I'm also not responsible for problems down the road.
FL
FL 2021-04-08
You sure?
Or create a new config but with same part number.
HS
HS 2021-04-08
i think, you absolutely need a new number. I understand that you're trying to avoid this, but: When you get your part numbered 087-1H-160-06-024 with chamfer - how to get back the sharp edge when it's already chamfered?
An other approach could be, designing a base part without any holes and chamfers. Use this and add your holes and stuff in the context of the assembly.
GS
GS 2021-04-08
I'm not aware of any way to do that.  As said, if the situation was reversed, and you wanted to add a chamfer in the Assembly it would be simple, but since you want the reverse I don't know of any way around having another Part configuration with the chamfer suppressed.
