Need to sort my BOM based on a created custom property "SR NO" but not by default numbers assigned to BOM
Hello Friends,
We have created a custom property named "SR No" (as a Number),
We want our BOM to get sorted by this property
Our sort settings are as shown in the image.
Still BOM is ignoring that SR NO and (sorting it by default numbers to the extreme left, Which are visible when we expand Left column of the BOM)
Thanks in advance
SolidworksBill Of Materials
Answers 8
HP
HP 2017-06-21 Best Answer
I didn't face this issue in my 5 years of SW work. But I guess there are two suggestions.
1. try saving this BOM as excel sheet, and the apply filter in excel sheet by SR NO. Then recall that sheet as BOM in SW.
2. Please see my attached photo. As per you photo you have only shorted it by SR NO at 1st level. Try applying SR NO shorting at 2nd and 3rd level also. As per my photo I have shorted it QTY. at all 3 levels.
comment imagecomment image
EL
EL 2017-06-21
Hello Hardik,
I tried your Option 2 but the same thing,
Whole idea is to create a BOM faster, I have more than 175 components with different configurations,
Every time using an excel may not be a fluent solution
Now I have to depend only on item numbers I suppose
Is it an error or something wrong with the sort feature?
Thanks
HP
HP 2017-06-21
Hello Eshan,
I don't think there is any error in sorting BOM. But the question is why you are sorting parts with sr no., as there is always sr no in BOM. (I don't think there is need to created custom property for SR no., better you create Item No and then named it like 1,2,3 so on).
Just for the information:
BOM is directly connected to your assembly tree. So you can always swipe parts/sub-assemblies up or down. This is a tedious process, but some engineers use this
Regards,
Hardik
JS
JS 2017-06-21
<p>Hardik Patel wrote:</p><p></p><p>BOM is directly connected to your assembly tree. So you can always swipe parts/sub-assemblies up or down. This is a tedious process, but some engineers use this <span class="emoticon-inline emoticon_grin" style="height: 16px; width: 16px;"></span> <span class="emoticon_silly emoticon-inline" style="height: 16px; width: 16px;"></span> </p><p style="min-height: 8pt; padding: 0px;"></p><p></p>
There are also macros available to sort the feature tree
HP
HP 2017-06-21
Its working in mine brother. Please see all photos. It's very simple.
comment imagecomment imagecomment imagecomment imagecomment imagecomment imagecomment imagecomment image
DG
DG 2017-06-21
What SOLIDWORKS version you're using with service pack? Also would you be open to share your files to check OR make dummy set of files showing the issue?
Also check and make sure that part configurations do not have a similar properties OR make sure if this is configuration property then two configuration do not have same values.
DP
DP 2017-06-21
I am not sure....(I will look into it), but I don't think that you can sort an indented BOM.    Wouldn't make sense to be able to sort it anyway, unless it is sorting inside each indent.
JS
JS 2017-06-21
Good Catch ​ - Sure enough the indented button is selected and you're right about the sort...
