Hi, need a bit of advice as to which CPU and GPU I should buy. I'm putting together a computer for my brother, but I'm not quite sure as to how powerful his machine needs to be.
He's just starting to learn SolidWorks, but he figures he'll be working with assemblies that features 50-200 parts, and sometimes more than this.
Price range around 15-16-17-1800\\\$
I'm looking at the i7-4790K or would the i5-4690K do a good enough job? And spend the money "saved" on a better GPU?
Would a FirePro v4900/W4100/W2100 or Quadro K600/K620 be good enough?
Or should I go for more expensive options like W5000/5100/7000, v7900, and the same pricerange Quadros?
My current build without GPU: Intel Core i7-4790K, Cooler Master Force 500 - System Build - PCPartPicker
SolidworksAdministration
Certainly put the most money on the CPU! not he GPU
Loads of good info here...
Your setup is more than adequate. Solidworks runs almost exclusively on the CPU. That being said I have had little trouble using consumer-grade computers to work with assemblies of that size. Keep in mind that the complexity of the parts plays as much a significant role as the number of parts. As the number of lines, surfaces, and constraints goes up so does performance demand. I run an i5-760 and a FireProV5800 on 8GB. I haven't needed to upgrade yet and often run off of my second computer which has an FX4100 with onboard video for small to medium assemblies.
It's strange that everyone says that SW is CPU driven, but using the wrong graphics driver for your card can cause all kinds of problems!
CPU = Horsepower
GPU = Transmition
Thanks for all the help, think I've landed on the i7-4790K / FirePro W4100 / 16GB RAM / Fractal R5
SolidWorks is mainly a since process application, so the faster the CPU speed the faster it work. But, if the Video card driver does not properly support OpenGL then that can cause problems. But, I have seen SolidWorks run wonderfully on systems that are not officially supported. SolidWorks can't test everything so they only officially support what they have been able to test and know the answers to the questions that will come up.
I would also recommend that you have at least twice as much memory as the assemblies you work with take up. That way if you have some other things going on at the same time you won't run out.
Hey, no one has mentioned this but you might want to look in to a SSD to put Solidworks on (If you're only going to use it for SW i wouldn't bother but if you want to put other things on there then i'd reccommend it, ive got SW, a few select games and programs on mine) I've got a 4790K, 8GB ram and a GTX 670 with SSD setup and it boots/operates in seconds.
