Is their anyway to tie your views, font, title block, etc. to your sheet size? To be more specific im having trouble scaling the models to fit a page and the same with the title block like its to small or to large. If their is not a way to do this how would you normaly do this? thank you.
Sometimes it requires an odd scale size. That is what I have seen done in the past.
The title block is always the same size, is it not?
As Alin said, if your title block is set in your sheet format for each sheet size, as it should be, then it won't change size.
Same for the font. The font should be the same size, regardless of the sheet format.
