I have tried many things here-can't seem to get it the way Iwant it. Need a white background, with a shiny effect on the gears.I have tried to use materials (chrome, etc.) doesn't work. Anysuggestions with the lighting? need a front view, up close.SolidworksGeneral
http://forum.solidworks.com/fo...=y&keyword1=photoworks
Turn on realview if your video card supports it. Then adjust your'ambient' light setting higher to brighten up the view.
Don
Not sure what exactly you are looking for. White backgroung, chromegears, not too shiny. What would you change from the attached jpeg?All I did with your file was to turn on the second spot light andreadjust the settings for both lights. Ambient, specular andbrightness and direction.
-Ben
I suggest adding as many lights as you can, I think realview onlyhandles 3?
Also, bold your text, extrude-cut (or extrude out) it, and add atiny bevel (chamfer).
