SWx 2013 SP4.0
When I'm working in a sketch the sketch's name is sometimes highlighted for renaming. Since I use hotkeys a lot what happens is I hit a hotkey and nothing seems to happen but what actually happens is the sketch gets renamed. I move focus back to the sketch itself but the same thing happens the next time I use a hotkey. This does not seem to happen consistently. I have the 'Name Feature on Creation' option enabled and maybe that's part of the problem but it doesn't seem logical to have the focus jump to the sketch's name when I'm editing the sketch.
Has anyone else seen this?
SolidworksUser Interface
Hi Bill,
Is the problem related to using F2 as a hotkey? Note that F2 is the Microsoft standard shortcut key for renaming items. So, it very well could be that depending on what your current selection is, hitting F2 is going to go into rename mode on the sketch.
Otherwise, I am not sure what might be happening and you should try exiting and restarting SolidWorks or rebooting the machine.
Thanks,
Jim
Hello Jim,
I don't use the F2 key for anything. This has happened across multiple sessions but is not consistent (right now it's not happening). It is strange in that the focus will jump back to the sketch name after each entity is created in the sketch. I'll try to pin down the trigger for this problem and get back to you.......Bill
I've often experienced the same problem, (F2 not involved) but put it down to working too fast and keying my shortcuts out of sequence. I will try to pay more attention & note what I did next time it happens.
Thanks Kelvin,
I now know I'm not crazy. Are you using the 'Name Feature on Creation' option?.......Bill
Bill,
I, too, have the name feature on creation option enabled and have run into the issue you are dealing with. I found that when you finish creating a sketch entity, the name feature on creation puts the focus on naming the sketch. So now if I hit a hotkey it starts renaming the sketch. I have found it to be annoying as I then have to hit ESC so the sketch reverts back to the name before the program jumped in. That being said, I still leave all settings as they are because I prefer to name my features as I go and the option speeds that part up. I chalk it up to being one of those annoyance that I just have to deal with.
Matt,
I have been putting up with it myself but yesterday I decided to at least ask about it. As it is I still find sketches named "tt" or "v", etc. I'm considering turning off the option to see if life is better that way.........Bill
I know the feeling.
I have found if I click in the background of the graphics area right after creating a sketch entity it changes the focus back to where the hotkeys will initiate a command. Just a tip.
for me it only refocuses to the sketch name after certain sketch functions - convert entities is the one I recall at the moment.
I just reproduced this problem for convert entities on both SolidWorks 2013 and 2014 (not sure about earlier versions). Those that are having this problem should definitely report it to your reseller, including any other commands that may cause it, so you get an SPR#. The more individuals that are having the problem and report it, the higher the level of visibility it receives to be addressed more quickly.
I'm surprised this is the first we've heard of it since I assume it is a very annoying problem.
Thanks,
Jim
Yes, Convert Entities does this consistently for me. Thanks for the effort to reproduce this one!.....Bill
we are still on 2012
We're supposed to be but someone in another group jumped the gun and went to 2013 so we're running both versions. It is a very large PITA.
spr #706731 from 2011
they are waiting for enough people to complain about this to work on it - so if it bugs you, tell your VAR to add you to this SPR
