If I right click on the material in the design tree to change the material it doesnt work. The drop down menu pops up with my preset favorites, I choose the material I want to switch it too, nothing happens.
The only way I can get it to change is by going all the way into the "edit material" dialog box, searching thru the huge list of materials to find the one I want and applying it that way.
In short, i can't "right-click" change my material.
Anyone else familure with this issue?
Thanks in advance
SolidworksParts And Features
Hei'ya Anthony, if it worked earlier or SW2013 gave us unexpected results for
normal operations/got buggy? we used to use the "copy settings wizard" and
re-install before going too deep- happened on a couple of occasions-
hope it helps- have good'n kelef
Even I had the same issue when I was using custom materials. The issue started just like that without even applying any updates.
What I did was, in edit material, I copied all the custom materials, deleted the old ones, renamed the copied ones and saved them. It started working fine after that. Yeah, I know its pretty hectic if you have a very long list of materials. May be somebody else can give you a better suggestion.
Krishna.
Go to SolidWorks Knowldge base and check if the solution offered in SPR #: 685629 works for you.
Krishna,
I dont believe I'm using custom materials. I say this because my "custom" tab in the material dialog box is empty. But i could be wrong as I'm not to familure with all thats involved with the material properties.
Upon further investigation, it's not the entire list that doesnt work. Seems the "stainless steel" material is the only one that I have found so far that it wont let me set. I can change to other materials with the right-click process no problem, but if I try to change it to "stainless steel" nothing happens.
Deepak,
I will get with IT and see if they can't try the registry edit.
thanks
go to edit material right click and copy the material, paste it in to custom material folder, rename it, save it and add it to your favourites, it might work.
