Material Properties > Non-linear elastic > Stress-Strain Curve
I am just wondering what strain value do I need to enter in this section of the materials property ? is this strain in terms of X, Y or Z  OR is it a ratio ?
Thanks for the help
SolidworksSimulation
Answers 10
SF
SF 2013-09-18 Best Answer
What nonlinear material are you using?
There are a couple of really good articles on this in the solidworks kb. This is also covered in the help and be nonlinear class.
SF
SF 2013-09-18
I am using Rubber. Its a custom made material from recycled rubber tires, i.e. synthethic rubber
SF
SF 2013-09-18
Which material model will you use for it?
What properties do you have access to?
SF
SF 2013-09-18
Also, do you know you are going to go into the nonlinear range? If you aren't, treating the rubber as linear will simplify your analysis greatly.
SF
SF 2013-09-18
I have
  • stress-strain curve
  • density
  • Poison ratio of 0.4995
  • Modulus from a material table for synthethic rubber
I would just like to do initial testing to see what the results are like before making a conclusion
SF
SF 2013-09-18
Yes this is going into the non-linear range. The stress-strain curve is not linear
SF
SF 2013-09-18
http://help.solidworks.com/2012/English/SolidWorks/cworks/Material_Models.htm?id=8a163f7530764f4fb4fc96967e1dfd04#Pg0
Take a look at the hyperelastic section. Make sure to check the swx kb for the right input info.
SF
SF 2013-09-18
thanks Jared. Appreciate the help.
Sorry I dont understand the acronyms, swx and kb
SF
SF 2013-09-18
So I am not able to just use Non-linear Elastic with a defined stres-strain curve ?
SF
SF 2013-09-18
Swx kb is the soldiworks knowledgebase. A wealth of knowledge available to customers on subscription. Customerportal.solidworks.com
Nonlinear elastic can work. But most of the time I see hyperelastic used. Especially for large deformation. Check the kb, read through the help and the training manual. That will help you decide.
