I attached a file of a screw assembly.
I am adding this to another assembly.
After adding the screw, I right click on it in the design tree and click on disolve sub-assembly.
After this I get many mate errors.
When mating the screw assembly to the plate I use 1 concentric mate for body of screw and hole in plate.
I use 1 coincident multi-mate for plate and bottom of top washer.
I don't understand why I get mate errors.
SolidworksAssemblies
I cannot open due to future version but you will need to upload the componets to the assembly also..
without opening the assembly I can suggest checking for fixed parts. you might have had fixed parts in the subassembly. when you disolved it, they remained fixed in the main assembly.
float them and you will be OK.
